SE255 cams and engine temp.
Old Jul 20, 2012 | 03:44 AM
Alykhan's Avatar
Alykhan
Originally Posted by bmb
103 not 130 lol
130 sounds cool though!!!
Old Jul 20, 2012 | 06:33 AM
MikeTD3's Avatar
MikeTD3
A yr ago everybody praised the 255's now all of a sudden everybody slam'n them. I dont get it.
That's because most people just follow the herd. I'm looking forward to putting the 255's in mine!
Old Jul 20, 2012 | 07:14 AM
lionsm13's Avatar
lionsm13
Oh, you're doing something different then?
Mmmmmmoooooooo..
Old Jul 20, 2012 | 07:56 AM
Spur56's Avatar
Spur56
The 255 is a good bagger cam, especially for the 96. The guru's tend to think they do not work as well in the 103's. They do produce a fair amount of heat because as stated they have a smaller overlap than some others. I have the 255's in my 96 and love the feel. They do run cooler than a stock motor, if you have a good tune. Nothing wrong with the 255's in the right application and with a good tune. If I had a 103, I would probably look at an Andrews or woods cam.
Cams have to fit your motor and your riding style. There is no perfect option. Do some research and pick what works for you. I very seldom go over 4000 rpm, so the 255 works for me, regardless of what the "herd" says. It pulls like a freight train 2 up in the hills of Tennessee.
Old Jul 20, 2012 | 08:59 AM
REDHEAD's Avatar
REDHEAD
Default Using the SE255 cams
I have over 20,000 miles(45,000 total) on my 09-96" King with stage one,V&H slip-ons both sides equal(no tinny box sound) SE Air,SE adjustable PRs slender tapers,TFI from Dobeck for the tuner. Now running a beta on Gen4. working Great.
Now I have the parts com'n together to go 103 using SE flat-tops,cyls bored by Kirby-ProDrag, 08 heads Blueprinted and CC'd installing PRvalves by Don Doorfman of Dewey's Heads up in Wa.
AND,,,Still gonna use the SE255's... My bike is NOT running too Hot now or will it later...
I added a Jagg oil cooler when I got my bike down to Az. using the thermostat unit by Jagg in front of the oil filter and mounted cooler to the left down-tubes...
I use Redline Products. 20/50 engine, MTL in Primary/clutch, ShockProof Heavy in the tranny.
My bike will start just fine, even on the Hottest days of 112* and runs cool... Oil pressure is running at 38/40 at highway speeds. Using the Original Comp. also.
I am doing a Beta for Dobeck on their Gen4 and will get the Finished updated programed one this week Before Sturgis I hope...
The gen 4 doesn't take out timing but TOTAL Control of you AFR and seeing Actual AFR on your gauge. Really helps on the Run-ability and Cooling of the engine. ECONOMY is there also, leaning it out a little on a long trip does improve your mileage by a lot and you can have it set to Not run too lean in the lower speeds at the same time also.
signed....REDHEAD
Old Jul 20, 2012 | 10:11 AM
roadrunner10's Avatar
roadrunner10
96" with 255s. I'm very happy with bikes performance. I didnt check avg eng temps before cam change, but i would say it runs a bit hot now. Not enough to worry about. I will stick with these cams until its time to up the displacement.
Old Jul 20, 2012 | 12:07 PM
MikeTD3's Avatar
MikeTD3
Mmmmmmoooooooo..
Not at all...I'm following last year's herd!
Old Jul 20, 2012 | 12:19 PM
quickster47's Avatar
quickster47
I have the SE255 cams running with a Cobra tuner and can truthfully say that my 2012 Street Glide now runs cooler than it did in stock form.
Carl
Old Jul 20, 2012 | 01:11 PM
AlphaInfinity's Avatar
AlphaInfinity
It sounds like the 255 cams were the perfect solution to get some attitude out of the 96. It also sounds like there is some debate about the 255 cams NOT being the right solution for the 103's.
From another 255 cam thread:
Originally Posted by 6 gun
here you go check this out
se-255 cam Kit
the ultimate in torque cams, this cam offers substantial
increase in low-end torque for engines up to 110 cubic
inches with compression ratios up to 10 to 1. the lowend
torque increases are great for heavy bikes or for the
person who routinely shifts below 4500 rPM and wants
the power available to pass without downshifting. the
cam still makes peak power above 5000 rPM so people
with lighter bikes will enjoy the torque increases without
feeling like the bike runs out of air at higher engines
speeds. these cams are used in the ’07-later street-legal
103 Stage II Kits and the 110 Stage I Kits. Compression
releases may be required depending on displacement
and compression ratio.
$299.95
se-254e cam Kit
this cam provides great low-end torque along with
good midrange. A good “all-around” cam, the Se-254e
is a good match for a Dyna, Softail or light touring bike
- road KingŽ, Street GlideŽ or road GlideŽ Custom -
when the aggressive rider desires a little more top-end
horsepower. In a 0-60 sprint or 1/4 mile drag race, the
Se-254e-equipped model would pull ahead of an identical
model with a Se-255 cam.
$299.95
Here is a 254E vs 255 cam thread:
https://www.hdforums.com/forum/touri...-big-bike.html
Old Jul 20, 2012 | 05:34 PM
lionsm13's Avatar
lionsm13
RILLY?
Don't think so....
