Starter help
Old Jul 20, 2012 | 05:46 PM
mikebaby's Avatar
mikebaby
Default Starter help
My starter is making sounds like either a "crunch" or almost like it is slipping. Any ideas other than replace it?
mikebaby
Old Jul 20, 2012 | 05:57 PM
Batman7349's Avatar
Batman7349
Check around for an Auto Electric store. They should be able to rebuild it since it is the same as a mitsubishi starter (depending on the year). I got mine rebuilt, solenoid kit, turn armature on lathe, and install new brushes for about $65.00. No more starter problems. Or do it yourself with a solenoid kit $40.00, and then emery cloth your armature, install new brushes.
Old Jul 20, 2012 | 10:12 PM
FatTony's Avatar
FatTony
Could it possibly be the starter clutch needs replacing?
Old Jul 21, 2012 | 12:05 PM
mikebaby's Avatar
mikebaby
No idea, it started right up this morning.
mikebaby
Old Jul 21, 2012 | 01:04 PM
1Canuck's Avatar
1Canuck
mikebaby
mine did the same. started perhaps another dozen times, then hit and miss, finally no starter clutch
Old Aug 31, 2012 | 10:30 AM
mikebaby's Avatar
mikebaby
I'm still having the issue, now sometimes I smell something burning, after a long and painful start. Is this the starter clutch?
I can buy a high-torque H-D starter online, and my dealer will install it for about the same, as parts and labor for them to order and install the new starter clutch.
Is it difficult to replace the entire starter assembly? I've done it on my old Stingray Corvette before, and the only pain there was the header needed to be removed to give me clearance.
Thanks,
mikebaby
Old Aug 31, 2012 | 10:40 AM
1Canuck's Avatar
1Canuck
mine was replaced under warranty. refer to the service manual. unless you open the primary, the starter is attached with two bolts and wiring plug so it looks easy enough to pull out.
Old Aug 31, 2012 | 11:13 AM
mkguitar's Avatar
mkguitar
1.) burning: DO NOT hold the starter button if the starter is not turning- the windings will burn up- which is fatal. this is preceded by a whining sound as the windings heat up
2.) diagnosis is key, is it the motor or the starter clutch- ( "bendix")
if the latter- dawg has posted the toyota part number for a $35 starter clutch.
3.) servicing the starter is easier than on a chevy
mike
Old Sep 4, 2012 | 01:00 PM
hogdropper12's Avatar
hogdropper12
Stage II
Default Starter Problems fix
go to www.starteroverridesystems.com to find a fix for your problem
Old Sep 4, 2012 | 01:03 PM
hogdropper12
Stage II
go to www.starteroverridesystems.com to solve your harley starter problems
Alan7407
13
Mar 18, 2026 07:12 PM
FLHTChip
11
Jun 24, 2013 09:25 AM
ironhead1987
Jun 30, 2012 11:43 PM
sunup420
EVO
Feb 7, 2010 11:58 AM
jdh1340
Mar 11, 2008 06:20 PM
