Electra Glide Heat
Old Jul 26, 2012 | 12:30 PM
racehorse's Avatar
racehorse
Default Electra Glide Heat
The engine heat on the right side of my '09 Ultra is pretty tough. I had an '04 Ultra with the same problem. It is totally stock. The handling and performance is much better than the '04, however the heat is about the same. I thought the routing of the pipes would help the heat problem, but I don't see any difference. I'm satisfied with the performance and sound. Any suggestions??
Old Jul 26, 2012 | 12:34 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Captian Itch crotch cooler.
Old Jul 26, 2012 | 01:01 PM
Kingspoke's Avatar
Kingspoke
The design of the twin cam motor is inherently hot (see http://en.wikipedia.org/wiki/Harley-...win_Cam_engine ), so most of the suggestions for reducing the heat will be better air flow, better exhaust (less restrictive/cat removal), and better tune(r) with correct AFR. None EPA cams also help. Heat protection from the Capt. Itch type devices, also helps.
I got my heat manageable and performance greatly improved but at a cost of $2,500. Good luck with the other suggestions to come.
Old Jul 26, 2012 | 01:13 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Our Crotch Cooler will run you about $80.00..If you have any questions or we can help you out just let us know..
__________________
www.Captain-Itch.com
Old Jul 26, 2012 | 01:18 PM
t-bear's Avatar
t-bear
I just ordered a Crotch cooler from Cpt. Itch, looking forward to see how it works
Old Jul 27, 2012 | 08:06 AM
racehorse's Avatar
racehorse
I hope there is a better remedy than this Captain Itch Crotch Cooler. It looks like a home maid piece of crap....
Old Jul 27, 2012 | 08:32 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I did all of these things as well, and it does make a big difference. My bike only gets overly warm on days when the outside temp is higher than the mid 90's. My carbed Night Train runs so much cooler than my EFI Ultra. The ability to run a little rich and cool everything down is a major improvemment.
Old Jul 27, 2012 | 04:35 PM
stoch's Avatar
stoch
Default Captain Itch
Put the crotch cooler on the wife's Lo and it worked wonders, and looks like it belongs on the bike. Definitely didn't look like it was home made.
Old Jul 27, 2012 | 08:35 PM
vwmark's Avatar
vwmark
Nicely made out of very thick leather. Not only helps with heat off the motor to the side bet also up through the seat.
Old Jul 27, 2012 | 09:13 PM
BBStacker's Avatar
BBStacker
Went with the FULLSAC true duals and solved the heat problem. My wife noticed it a lot more than I did. Best I can tell ya.
