5000 mile service includes?
Old Jul 30, 2012 | 09:40 AM
LDB415's Avatar
LDB415
Question 5000 mile service includes?
I was told by someone that all fluids are changed every 5k miles, not just the engine oil. Is that correct? The transmission and diff fluids are also changed every 5k? That would make the cost of the 5k service seem more reasonable but it seems awfully short intervals especially if using synthetics. There sure is a lot to learn before jumping in. Thanks for all the helpful and friendly replies to what I know are absolute beginner questions. This is one of the most user friendly forums I've ever seen.
Old Jul 30, 2012 | 09:46 AM
AlphaInfinity's Avatar
AlphaInfinity
The Harley website has the maintenance schedule for your motorcycle:
https://www.harley-davidson.com/en_U...schedules.html
It is also in the manual. They will follow the suggested schedule. The chaincase and transmission fluids are NOT changed at the 5k intervals according to my touring schedule. They basically change the engine oil and filter and inspect the bike. They may also adjust a few things like the clutch.
fabrik8r's Avatar
fabrik8r
Everything with an "x" in the 5000 column of the service schedule in the manual is what gets done.
Old Jul 30, 2012 | 09:49 AM
LDB415's Avatar
LDB415
I don't have a bike yet so no manual however I may visit a dealer today and if it isn't crazy expensive might buy the manual to the SG while I'm there. Thanks.
Old Jul 30, 2012 | 10:32 AM
Uncle Larry's Avatar
Uncle Larry
This might help you ...
http://cdn-5.psndealer.com/e2/dealer...20web%2008.pdf
Old Jul 30, 2012 | 12:04 PM
TwoBlue02's Avatar
TwoBlue02
Your $$ but I would hold off on buying a manual. You can view online and more than likely one will come with a used bike and for sure will be there on a new one.
Old Jul 30, 2012 | 04:17 PM
LDB415's Avatar
LDB415
That's great. Thank you.
Old Jul 30, 2012 | 04:19 PM
LDB415's Avatar
LDB415
I'm sure it varies depending on dealer but can anyone give a rough estimate of cost of the 5k and 10k services? From that chart it appears on a 2004 or newer bike you don't do the 2.5k services anymore, just the 5k and 10k. I'm sure the 10k is more since it covers more. Just curious roughly what to budget for routine service stops.
Old Jul 30, 2012 | 04:24 PM
1flhtk4me's Avatar
1flhtk4me
Your better of calling shops around you.
Prices that are given here vary a lot depending on your location,just like some of the bike prices.
But anyway $225-$450 I guess.
Old Jul 30, 2012 | 04:26 PM
one-up's Avatar
one-up
The dealer I use changed oil in all 3 holes on my 2011 Electra Glide Classic. That would be engine oil, transmission and primary chain case. If you've ever seen the oil in the primary chain case after 5,000 miles, you would want it changed. Some dealers will say they change transmission and primary on "as needed" basis. All 3 holes need to be changed every 5,000 miles in my opinion.
