wont start
Old Aug 1, 2012 | 10:35 AM
dalefarley's Avatar
dalefarley
Stage II
Default wont start
I have a 2000 RoadKing with manellee fuel inj and wont start and then will! Backfires and then dont Starts and runs fine but wont restart Starts with a little trottle ?? Replaced Crank sensor and timing sensor Can someone help me PLEASE
Old Aug 1, 2012 | 10:38 AM
dalefarley's Avatar
dalefarley
Stage II
2000 roadking Starts then wont start! I have replaced Crank sensor and timing sensor! Backfires sometime on Cranking! When starts Runs Great but wont restart?
Old Aug 1, 2012 | 11:48 AM
mrfikser's Avatar
mrfikser
have you checked for water in the gas??
Old Aug 1, 2012 | 12:11 PM
larsfum's Avatar
larsfum
First things first. Pull any trouble codes. Check that the battery is good, and providing proper voltage to the system. Do you have a fuel tuner on it? If so, try running it with the tuner disconnected. I think I remember something about the 2000 model having an issue with a broken wire leading to one of the injectors. Try wiggling the wires leading to the injectors. If you get the same symptoms then you know where the problem lies.
PhillyRoadKing
11
May 27, 2020 01:40 PM
Vidster
May 6, 2019 05:47 PM
Vidster
EVO
Mar 19, 2019 08:20 AM
JR-Boston
Jan 9, 2015 11:04 AM
Rhino-1
Electrical/Lighting/Alarm
Sep 11, 2014 04:08 PM
