Headerpipe 2009/96 vs 2012/103
Old Aug 3, 2012 | 12:58 PM
GunGeek's Avatar
GunGeek
Default Headerpipe 2009/96 vs 2012/103
Will the catless 2009 headerpipe off a 96 fit on a 2012 103 Engine?
Old Aug 3, 2012 | 01:23 PM
Coastiejosh's Avatar
Coastiejosh
yes it will fit, BUT the O2 sensors are not the same. 2009 had 18mm O2 sensors, 2010 and later are 12mm sensors. I went with 09 head pipes, so I could use the auto tune set up for my power commander. I have a 09 head pipe if you are interested.
sfmichael's Avatar
sfmichael
Yes but O2 sensor placement and size are different. Cut yours open, remove cat, and reweld. Or go to ebay there's a place that does it for a hundred bucks. They swap pipes with you for one already done. $150 plus shipping ($25) and they credit you back $50 when you send them your pipe (return freight included in the $25 shipping). Wild Pig Pipes is the heading on the ad.
Old Aug 3, 2012 | 01:26 PM
mkguitar's Avatar
mkguitar
..or just get bung adapters from nightrider.com or just about any muffler shop.
allows 12mm sensor on a 18mm header
the spacing of the 09 49 State* style header has the o2 sensors somewhat more isolated from each other.
some riders suggest that in a "de-catted" '10+ header, each of the 2 sensors may get spurious readings affected by the other cylinder-
I have no experience with this ( 'cause my newest bike is an 09) but can see where this may occur at specific RPMs determined by the movement of pulse waves in the exhaust tract. these waves are influenced by rpm, muffler design and cam profile/timing, so will vary from bike to bike unless identical
mike
*Ca version has a cat
Old Aug 3, 2012 | 02:23 PM
TUCCI's Avatar
TUCCI
Yup sure will....
Old Aug 3, 2012 | 03:25 PM
TNCarters's Avatar
TNCarters
Personally running an aftermarket pipe but thought I would mention many places like Phat Performance also sell bungs that can be welded into the collector of an '09 head pipe. They also have plugs for the earlier model sensor bungs. Can't speak to the cross talk between sensors.
TOUCHNGO
2014-2024 Touring Models
Aug 10, 2015 05:09 PM
M109Rrider
May 12, 2014 05:22 PM
kyleplusitunes
Jul 23, 2011 09:40 PM
sportyrider1
Apr 3, 2011 08:46 AM
VaThumper
19
Feb 11, 2011 02:04 PM
