How Common is a Bad ECM?
Old Aug 3, 2012 | 07:35 PM
drukanfu's Avatar
drukanfu
Originally Posted by PFWiz
It might just be corrosion on the ECM plug. Before you do anything expensive. Unplug the ECM spray both sides with contact cleaner and then use some di-electric grease before reassembling. For $10 this might fix your problems...
Yeah That !.......once they work for a while and get burned in they are usally good for alot longer. A little corrosion will screw things up.
Good luck !
Doug F
Jan 11, 2018 07:38 AM
Hausguy
Aug 21, 2017 11:23 AM
b2_lamb
2014-2024 Touring Models
Oct 16, 2014 06:48 PM
1flhtk4me
Sep 14, 2013 09:51 PM
TexasVet
Apr 20, 2011 01:20 PM
