ABS Problem
Old Aug 5, 2012 | 07:24 AM
woodmaniac's Avatar
woodmaniac
Default ABS Problem
If I start before I rollback, the ABS light will remain on until I stop, shutdown and start agian moving forward. I had the same Problem while under warranty. My dealer stated it was a broken wire. Wish I had asked more questions because now I do not know where to start.
Old Aug 5, 2012 | 07:33 AM
Bruce00's Avatar
Bruce00
Broken wire will make the abs light flash, have first hand knowledge on that one......lol
Doesn't the light remain "on" until the bike reaches 5 mph?
Old Aug 5, 2012 | 07:45 AM
woodmaniac's Avatar
woodmaniac
Default ABS Light
No the light stays on and the ABS does not operate. I tried a quick stop to find out. However, if I rollback before I start the bike, the ABS functions properly.
Old Aug 5, 2012 | 08:07 AM
Bruce00's Avatar
Bruce00
When you say rollback, do you mean rollback the throttle or are you talking about rolling the bike out of the garage?
Old Aug 5, 2012 | 09:21 AM
woodmaniac's Avatar
woodmaniac
Default ABS Problem
Rolling out of the garage. If I start first the light blinks until I start forward then after I start rolling the light stays on. If I back out of the garage before starting the light operates normally.
Old Aug 5, 2012 | 09:45 AM
Northbound Southerner's Avatar
Sounds like the issue is with the sensor in the front wheel. Hate to say it, but to fix this one, you are probably headed to the dealer. The other option is to throw parts at it until it works...
Old Aug 5, 2012 | 10:37 AM
Pondskipper's Avatar
Pondskipper
I would say this is likely the same on all the ABS equipped bikes, the ABS sensor thinks there is a fault as it looks like the wheel is locked so disables the ABS for safety, the answer is to roll the bike back first then start the motor.
Old Aug 5, 2012 | 10:44 AM
Never had to roll mine...bike don't care how it's parked...
baldguy13
2014-2024 Touring Models
May 13, 2014 09:38 AM
glide2005
Jan 17, 2011 11:56 AM
batman10
May 18, 2010 08:33 AM
wulffman
Feb 22, 2010 07:18 PM
DocDyna
Dec 2, 2009 07:59 AM
