Stage 1 SE AC only
Old Jan 19, 2007 | 07:59 AM
jimclaypool's Avatar
jimclaypool
Default Stage 1 SE AC only
Will I see a power improvement with just a SE AC installed on my stock 07 Ultra with stock exhaust? If I get a PCIII is there a map for just a SE AC with stock pipes?
Jim
'07 Black Cherry Ultra
Old Jan 19, 2007 | 08:05 AM
Pastor John's Avatar
Pastor John
Default RE: Stage 1 SE AC only
Jim, just about anything that helps the engine move more air through it will result in a power improvement, but once you move more air you'll need to add fuel to the mixture to avoid a lean air/fuel mixture and to maximize the combustion potential. The PCIII is considered one of the best of the fuel management systems out there because of its programmability. Many folks here speak very highly of Jamie at fuelmoto.com; you might drop him a line and see what he says about the equipment combination you are considering. He may already have maps available for that combo. If not, many HD dealerships can tune the PCIII through their dyno.
Old Jan 19, 2007 | 07:05 PM
rdam's Avatar
rdam
I don't have a PCIII.....YET.......But based upon what I've read on the forum, I think that is money well spent. I have the Stage 1 download, and my current set-up works very well. However, I will soon buy a PCIII, and will probably be pleasantly surprised. The point is, with the new aircleaner, you SHOULD change the air/fuel mixture for best performance. PCIII is a better investment over Stage 1 download for that purpose. FuelMoto appears to be the best place for service and support.
Old Jan 19, 2007 | 07:42 PM
ndotken's Avatar
ndotken
ORIGINAL: jimclaypool
Jim
A highflow SE air cleaner would increase the air flow into the engine. And I'm no mechanical engineer, but it would seem to me that putting more air into an already lean fuel mixture is not a good idea.
I think a PCIII or SERT is a must if you're going to maintain an optimum A/F mixture.
Old Jan 19, 2007 | 07:57 PM
stglideblk's Avatar
stglideblk
my dealer said hd will not warranty any bike with sert or pciii
Old Jan 19, 2007 | 08:06 PM
ndotken's Avatar
ndotken
ORIGINAL: stglideblk
I'd find a new dealer. They all don't have that attitude.
Old Jan 19, 2007 | 08:18 PM
gghawg's Avatar
gghawg
1st Gear
the latest from HD is that they will not warranty Race Tuner installs any longer.
Old Jan 19, 2007 | 09:29 PM
wnogood's Avatar
wnogood
Jim
No, and no.
nogood o~`o
Old Jan 19, 2007 | 09:41 PM
cunfuzed's Avatar
cunfuzed
i'd find a new dealer!!!!!! i just had my sert put on myultra by my dealer with no warranty voided! and i have the high airflow kit but also changed pipes does make a big difference losing the lean condition!!! af ratio flat now 13.2 across the board and the bike screams!!!!!!!!
Old Jan 19, 2007 | 09:49 PM
jj9150's Avatar
jj9150
i just ordered my pcIII on recomendation form a tech at my dealer, due to its removablity he said that it could be pulled out and nobody would ever know that it was there. i dont know anything about the sert but i guess it is traceable according to him.
