Air filter question
Old Aug 6, 2012 | 10:01 PM
Dirtball's Avatar
Dirtball
Default Air filter question
This may have been asked but I used the search function and could not find an answer. Not having the money to spend on major upgrades, I was thinking of replacing the stock air filter with a K&N but still retain the stock cover. There is one listed in the HD Catalog. My question is if I just change the filter and nothing else do I have to have the engine remapped? The only other mod I have made is took off the stock slip-on mufflers and put on Reinhart slip-ons. As I said major mods are not in the budget soon but we are working on that.
Old Aug 6, 2012 | 10:05 PM
TUCCI's Avatar
TUCCI
Go to JPCycles and search air breathers. Many of the kits you can reuse the stock breather cover or you can buy a KN to replace the stock filter. If you leave the cover stock you shouldn't have to remap it but a reasonable priced tuner like a PCV would a just enough fuel to wake the engine up a little and that's always a good thing.
Old Aug 6, 2012 | 10:19 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
The stock motors AFR is lean to begin with. When you add a free flowing A/C unit like a K&N you're allowing the motor to draw in more air than the fuel is calibrated for, which makes it even leaner = equals a hotter motor & more prone to pinging. An EFI controller is the best option although the dealer can do a Stage 1 download that helps some. Either way, you need to add more fuel.
Old Aug 6, 2012 | 10:43 PM
stuart1270's Avatar
stuart1270
You already have the mufflers. You can go with the vance&hines naked O2 air cleaner $125.00 internet price comes with K&N filter. Which allows you to keep air cleaner cover (football) however as stated you should add fuel management. V&h has the fuel pack. About $250.00 internet price. Good luck.
Old Aug 7, 2012 | 12:26 AM
mkguitar's Avatar
mkguitar
bang for buck hi flow air cleaner is the ness big sucker on ebay from easternpc... about $120
OR you can take a hole saw to your stock air cleaner housing and drill 5 to 7 3/4" holes in the side of the plastic backing plate
at this point you have increased flow going into your motor and increased flow out and tuning compensation will almost certainly be needed ( although some do fine with out, it varies--- run premium fuel only)--- if your bike has o2 sensors ( 2007 and up) you can add nightrider.com xieds for $100 to $130 depending on year of bike, these plug into the o2 sensors and will cause the ecm to put out a slightly richer mixture
Mike
Old Aug 7, 2012 | 03:22 PM
mllgator's Avatar
mllgator
What you are describing is a "Stage I Kit". The kit is comprised of a back(er) plate and a free flowing air filter (A/C). 2 filters are availble from H/D, a std. ($25) or one made by K&N ($65).
The K&N is able to be cleaned, although I have cleaned my std unit several times - the choice is yours.
You will get a TON of comments on the "re-map, add a tuner, or do nothing" question. To me, the re-map was the best option ($150) - I know it will run as designed, it is WAY less $ than a tuner & doing nothing was not an option (for me) given how much $$$ I have in the bike.
Old Aug 7, 2012 | 03:37 PM
TWIN CAM 96's Avatar
TWIN CAM 96
I would just buy the K&N filter & run the High Test Gas as normal if you start to hear pinging you need to do a remap if not Happy Trails.
City Worker
Jun 12, 2017 08:42 AM
desertwolf
Feb 13, 2014 07:19 PM
BadNight09
Mar 21, 2009 11:49 AM
ninetyzero
Dec 7, 2007 06:21 PM
bgc912
Exhaust System Topics
Sep 14, 2006 10:32 AM
