vance and hines
Old Aug 8, 2012 | 01:20 PM
silverdollar1964's Avatar
silverdollar1964
Stage III
Default vance and hines
Hi, hope im in the right area. I have 2011 streetglide with Vance and Hines round slash cut mufflers(slip ons). I purchased the quiet inserts to cut down the muffler noise, The problem that Im having is removing the baffle so that i can install the insert I've tried just about every and still they wont budge.I remove the 2 bottom screws sprayed it with w-40 bang them with a rubber mallet and nothing they only have about 300 miles on them. Any and all suggestions are appreciated.
Old Aug 9, 2012 | 09:39 PM
makinthemove's Avatar
makinthemove
Slap hammer
Old Aug 9, 2012 | 09:51 PM
one-up's Avatar
one-up
I have that same muffler and like it the way it is. Try ear plugs and save yourself a lot of grief. Don't mean to be a smart a$$, but it is an alternative that works. I used ear plugs when I had a V&H Pro Pipe.
Old Aug 9, 2012 | 09:58 PM
mkguitar's Avatar
mkguitar
what ever you do, don't be pounding on the mufflers mounted to the bike...you can cause damage to the headers and mounts-- it gets expensive.
mike
Old Aug 9, 2012 | 10:30 PM
TUCCI's Avatar
TUCCI
Take the slip on with the two bolts off, put a 2x4 on the floor, now gently in an up and down motion slam the back end of the pipe against the block of wood. After a few taps the baffle will slip out the end....repeat for other side. Coat the inside with anti-seize compound inside the pipe prior to installing the new baffle so you wont have to struggle with it again.
dulley
Apr 17, 2013 05:13 PM
ben310135
Touring Parts
24
Jul 26, 2012 02:07 PM
FrankP
Aug 22, 2011 10:00 PM
Rickr01
May 2, 2011 07:27 AM
Goody357
Exhaust System Topics
Jul 9, 2007 03:13 AM
