Front axel pinch bolt stud broke. Please help.
Old Aug 10, 2012 | 12:10 AM
rbb469's Avatar
rbb469
Default Front axel pinch bolt stud broke. Please help.
Does anyone know if the stud is threaded into the lower fork or is it a spline type that's tapped in? Thanks in advance. Ricky
Old Aug 10, 2012 | 12:47 AM
mkguitar's Avatar
mkguitar
this diagram will help.
http://partsfinder.onlinemicrofiche....T-(NON-FAIRING)
if you want part numbers, put the item in the 'shopping cart' the # will be shown at check out and you can jot them down.
then you can call your local dealers and see who has a new stud in stock.
Mike
Old Aug 10, 2012 | 12:54 AM
AlaskaAviator's Avatar
AlaskaAviator
I would be very surprised if its pressed in.
Old Aug 10, 2012 | 01:14 AM
HOG_0308's Avatar
HOG_0308
its threaded. i broke one also on my 08. grab some vise grips and twist it out. 5.00 fix.
Old Aug 10, 2012 | 02:22 AM
04roadglide's Avatar
04roadglide
2nd Gear
It is threaded,like previous reply vise grips will work.
Old Aug 10, 2012 | 09:54 AM
rbb469's Avatar
rbb469
Thanks for all the replys! I'm headed to the HD dealer to pick up a couple studs. Thanks, Ricky
Old Aug 10, 2012 | 10:04 AM
mainshaft's Avatar
mainshaft
Curious - Did you use a TQ wrench or German TQ it?
Old Aug 10, 2012 | 10:09 AM
rbb469's Avatar
rbb469
ft-Lbs instead of in-lbs.
Old Aug 10, 2012 | 10:12 AM
EasternSP's Avatar
EasternSP
Ok, ya got my curiousity up. What's German TQ?
Old Aug 10, 2012 | 10:27 AM
mainshaft's Avatar
mainshaft
Using a wrench, estimating the TQ. Gooood an tight
