J&M amp input switch position W/Sony HU
Old Aug 11, 2012 | 03:59 PM
Moneywoes's Avatar
Moneywoes
Default J&M amp input switch position W/Sony HU
I currently have the J&M 500W amp and stock HK headunit. The amp input switch is set to high.
I am changing headunits, putting in a Sony marine from biketronics, the Sony headunit has RCA outs to the amp. Should I use the RCA outs to the amp instead of the speaker wire outs to the amp like the HK unit without RCA's use.
If I use the speaker wire outs to the amp I know the amp input switch will stay set on High. If I use the RCA outs from the Sony to the amp do I need to set the amp input switch to LOW?
Is there a benifit to using the RCA's out of the Sony to the amp over using the speaker wire outs from the Sony to the Amp?
Thanks
Old Aug 11, 2012 | 04:30 PM
acchd's Avatar
acchd
The RCA low level inputs should sound better I'd go with them since you got them. Your correct if you use RCA inputs set amp input switch to LOW.
Old Aug 11, 2012 | 06:00 PM
Moneywoes's Avatar
Moneywoes
Thanks ACCHD thats what I needed to know.
Old Aug 11, 2012 | 06:16 PM
acchd's Avatar
acchd
Moneywoes you'll enjoy that new HU with Biketronics control module! With the new HU I picked up Bluetooth, HD radio & USB Ipod controls. It is was like why didn't I do this a long time ago !
puzzled1
Audio Systems
Jun 27, 2022 06:44 PM
torchmaster
Audio Systems
Mar 17, 2018 03:48 PM
No U Glider
Audio Systems
Oct 5, 2016 04:31 PM
wiguy
Audio Systems
Mar 15, 2016 09:39 AM
CGLTD
Audio Systems
18
Oct 15, 2015 07:47 PM
