leak down test
Old Aug 12, 2012 | 08:44 AM
sporacer's Avatar
sporacer
Originally Posted by 2009blackpearle
well guess i wont be doing that test. will still try to blow some air in to cylinder to see it i get air back out valve, will check push rod turns if i get leakage then looks like head will be comming off .
There should be no leakage at the valves. Just make sure your on the compression stroke or take the rockers off. Only a slight leakage into the crank case from the rings.
Are you using se roller rockers? If you are the valve covers need to be clearanced.
75hdxlh1000
Jun 19, 2017 09:50 AM
TStephen
Apr 19, 2017 12:58 PM
Pirate9687
Engine Mechanical Topics
Sep 14, 2012 10:44 AM
47Harley
Ironhead
Dec 29, 2009 02:22 PM
ptcruiser
EVO
Oct 7, 2009 02:52 PM
