Slight clunk when coming off throttle
Old Aug 11, 2012 | 08:18 PM
P51Driver's Avatar
P51Driver
Default Slight clunk when coming off throttle
Today I noticed that when coming off the throttle like when coming to a light I feel a slight clunk in my left handlebar.
This is the first time I have noticed this and as of today the bike has 600 miles on it.
Also one time today when slowly accelerating away from a light I had the trans do what seemed like it jumped out of first gear and I felt a grinding chucking noise for only a second as I immediately pulled the clutch in and positively shifted it back into first.
After that no issues. Is it possible when downshifting as when coming to a light that I didn't shift all the way into first with a lazy downshift?
BTW I noticed the clunk in the handlebar before the shift issue.
2012 Street Glide
Old Aug 11, 2012 | 08:42 PM
mkguitar's Avatar
mkguitar
shifting does need to be "positive" and after downshifting- like while sitting at a light with the clutch pulled in, the shifter may 'bounce" out of position from the drivetrain vibrating-
clunk- when slowing the weight shifts forward- could be anything from a can of coke rolling forward in the saddlebag to the forks compressing.
the bars are mounted on rubber bushings, so there will always be some play in them
mike
Old Aug 11, 2012 | 09:06 PM
P51Driver's Avatar
P51Driver
Should I be overly concerned with the condition of the gears in the tranny after this incident?
Should I have the dealer check the tranny?
Old Aug 11, 2012 | 09:08 PM
tubeman426's Avatar
tubeman426
Sounds like the compensator, its normal in the situation you describe. Its the slack being taken up from accel and deceleration.
Old Aug 11, 2012 | 09:35 PM
mkguitar's Avatar
mkguitar
nope- gears'll be fine.
these bikes are tough
mike
Loose Nut
Sep 28, 2019 05:50 AM
burnsy87
Jun 20, 2016 04:34 PM
jcd15
May 5, 2008 09:48 PM
Bikemeup
Jul 5, 2007 11:22 AM
sws1
May 14, 2006 01:21 PM
