Maybe a dumb question!!!
Old Aug 12, 2012 | 10:34 AM
jeffreydsilver's Avatar
jeffreydsilver
If you turn off the kill switch first, the bike will shut down. If you turn off the ignition switch first, the bike will shut down. Nope! No difference!
Old Aug 12, 2012 | 10:48 AM
Mickey D's Avatar
Mickey D
I modified my kill switch with a coil lanyard, just in case I fall off.
Old Aug 12, 2012 | 10:59 AM
Duracell's Avatar
Duracell
Originally Posted by Wally
It's pretty simple actually. The lawyers made them put that in the manual in case some dumbass is too simple minded to realize his bike is in gear when he reaches for the ignition switch with his left hand.
Most people look for the green light , then turn it off with the ignition switch.
the procedure in the manual is about liability, not damaging the bike.
The bike won't start in gear unless the clutch is pulled in so I doubt that has anything to do with it.
Old Aug 12, 2012 | 11:07 AM
Glockmeister's Avatar
Glockmeister
I used the ignition at the end of a ride once, then the bike yelled, "you're doing it wrong!" I thought it was my wife yelling.
Old Aug 12, 2012 | 11:33 AM
TWIN CAM 96's Avatar
TWIN CAM 96
I would think if you use the the run/stop switch you won't ended up locking your front end in an emergency if you happened to turn it that way.
Old Aug 12, 2012 | 11:56 AM
TUCCI's Avatar
TUCCI
Originally Posted by carrmat
Do a search, lots of threads on this and just as many opinions on the topic.
No one ever seems to have a problem with doing it either way. Lots of people never touch the rocker switch and just use the main switch.
Yeah that's what I do. No such thing as a dumb questions unless you ask after you've already screwed things up and shoulda asked before you did it
skratch's Avatar
skratch
Originally Posted by Skeeter229
I have a 2010 Electra Glide Classic and I was wondering if there is a proper way to shut down the engine. The manual says to turn off the engine run switch and then the ignition switch. Does it matter if you shut off the ignition switch first? Does it do any damage if it is turned off before the run switch? I shut down the bike with the ignition switch and someone told me that you can do damage to the electrical system but I don't believe him.
Thanks
either way is fine. just don't do it by coming to a complete stop, holding the front brake, downshift into first, and pop the clutch.
Originally Posted by bigheadted
I would be thinking if the stinking bottom feeding lawyers were so concerned about starting the bike in gear they would have safety switches on the clutch and pressure switches on the seat as well as a neutral only start. Not buying that one.
well, there is a neutral safety switch on the 2007 and up models. and it will only start in gear if you have the clutch pulled in. a neutral only start would be less safe. if you stall it in an intersection, you are a sitting duck while your sitting there going back and forth from 2 to 1....
Old Aug 12, 2012 | 12:06 PM
Leftcoaster's Avatar
Leftcoaster
[QUOTE=carrmat;10193668]Do a search, lots of threads on this and just as many opinions on the topic.
Do a search on shutting off your motorcycle?
Jeezus, Joseph and Mother Mary....just reach up and turn that great big switch in the center of the handlebars. It'll shut down sure as cow $hit splats when it hits the dirt.
Old Aug 12, 2012 | 12:18 PM
zion's Avatar
zion
Either way.
In MSF we teach the run switch, because as mentioned earlier, it's about keeping hands on the handlebar "just in case".
You won't hurt your bike using the key/ignition switch.
Old Aug 12, 2012 | 12:34 PM
circlenine's Avatar
circlenine
[QUOTE=Leftcoaster;10194156]
I'm buying you a beer if I ever run into you. Great response.
