Shock Pressure Puzzle
Old Aug 13, 2012 | 04:44 PM
FDHOG's Avatar
FDHOG
Default Shock Pressure Puzzle
When I ride solo, I keep my pressure at 38#. It'll stay at 38 indefinitely with no pressure loss.
When I ride 2up, I jack it up to 44#. After most rides, it drops down to about 40. That's after just 100 miles of riding.
Should I be pumping up past 44# and bleeding back down to 44?
There are no obvious leaks since it holds at 38.
Confused!
Old Aug 13, 2012 | 04:53 PM
drukanfu's Avatar
drukanfu
Seeing how you have more pressure in the same area, their is a higher percentage of pressure loss.
Volume = pr2 x height
V = pr2 h
Surface = 2p radius x height
S = 2prh + 2pr2
Old Aug 13, 2012 | 04:56 PM
FDHOG's Avatar
FDHOG
It's been a long time since my last physics class.
So what you're trying to say is that I have a slooooow leak.
Old Aug 13, 2012 | 05:08 PM
drukanfu's Avatar
drukanfu
No leak, but just an initial lost that is noticed at a higher pressure.
Another words, pretty normal. It should stay at 40psi. Ambient air temp of the day can change it up or down. I'd just leave it at 40psi I guess as a happy medium, or crack'er up to 50lbs for 2-up.
Old Aug 13, 2012 | 05:11 PM
mkguitar's Avatar
mkguitar
...and changes in air density whether from altitude or temperature
mike
Old Aug 13, 2012 | 05:19 PM
1st 96 ultra's Avatar
1st 96 ultra
sorry had to ask , how big is # 2 passenger
Old Aug 13, 2012 | 05:20 PM
DannyZ71's Avatar
DannyZ71
I have the same issue. Anything below 40 and it basically stays there. If I pump it up to 50 for two up riding, by the end of the ride, it's down in the 40's too. Kind of a pain as I have to pump it up again before we go for the next ride. Also, I can't really tell, when riding solo, between 15 and 40 lbs. Seems to ride the same no matter what.
Old Aug 13, 2012 | 05:27 PM
Texas Fat Boy's Avatar
Texas Fat Boy
I don't know if I can help but I always pumped mine up past what I wanted,
then let it back down with the pressure relief valve.
Old Aug 13, 2012 | 05:51 PM
FDHOG's Avatar
FDHOG
She's 5'10" and 155#. Not bad for 52.
Pumped it up to 50 and used soapy water to check for leaks. Nothing!
Old Aug 13, 2012 | 07:23 PM
hbsoldier3's Avatar
hbsoldier3
I was told by the dealer not to exceed 35#s PSI max, now I'm confused I run 15#s and 25#s for 2up
