Got a 1991 Electra Glide which has a vibration through highway pegs when turning left at speed,throttle on and it tends to go away,back off comes back,anyone got any ideas where to start looking?
place 2 X 8' flourescent light tubes on each side of the rear tire, the distance from each tube to the front wheel should be the same. ( or other known accurate straight edges)
the manual has a number of checks and how to's for the drivetrain to chassis alignment.
and you may be looking at bushings for the swingarm and the motor mounts.
try to determine if the vibes are speed related or rpm related.
you feel them in the hiway pegs- what about through the bars or the floorboards ?
