Smart Security Problem
Old Aug 14, 2012 | 08:15 PM
vickers1's Avatar
vickers1
Default Smart Security Problem
Just received my 68200-07A Smart Security system I bought on ebay for my 2012 Street Glide. It was advertised to be new. Plugged it up and was starting the procedure to marry it to the ECM. Switched the bike on and oh crap! the turn signals started flashing and the bike won't turn over. It looks like someone has either programmed it to another bike or tried to. It came with 2 (new in the plastic) fobs.
Is there a solution to this or does it need to be returned to sender? I sure would like to use it but I can't get it into programming mode. Switching the bike on just sets the alarm off.
Old Aug 14, 2012 | 08:26 PM
skeeter 250's Avatar
skeeter 250
There maybe a tab you need to pull out of the fob for battery to contact. If not I dunno. Good luck. Also check for battery in fob.
Weavr99FLHT's Avatar
Weavr99FLHT
Maybe the fobs need a battery change?
Old Aug 14, 2012 | 08:31 PM
vickers1's Avatar
vickers1
No the fobs will have to be programmed to the module by the dealer. The problem is that the security module won't program to the bike.
Old Aug 14, 2012 | 08:53 PM
aviscomi's Avatar
aviscomi
+1 Its not "plug & play" the dealer needs to program the Fob(s).
Old Aug 14, 2012 | 09:39 PM
jjnoble's Avatar
jjnoble
The TSM/TSSM will not enter configuration mode on the first
attempt after battery voltage has been removed from terminal
1. This will occur after any of the following situations:
Battery disconnect or power drain.
Battery fuse or maxi-fuse removal.
Connecting Breakout Box to TSM/TSSM connector.
Therefore, after all battery reconnects, the configuration
sequence must be modified as follows.
1. Set run switch to OFF, cycle ignition key ON-OFFON-OFFON
and press left turn signal switch
twice.
2. Repeat step listed above.
3. Continue with configuration sequence listed.
Old Aug 14, 2012 | 09:46 PM
EricD10563's Avatar
EricD10563
This might apply to you:
ACTUATION
1. See a Harley-Davidson dealer to activate the key fob to
the TSSM, HFSM or BCM.
NOTE
You can activate the TSSM fob by referring to the procedure
in the electrical diagnostic manual
http://www.harley-davidson.com/en_US...ts/-J04082.pdf
Old Aug 14, 2012 | 09:48 PM
PistonPuller's Avatar
PistonPuller
I was in the same boat awhile back and bought what I thought was a "new" tssm. I could not get it to marry to the bike so I caved in and took it to the dealer to have them use the digi thingamabob. Turns out the tssm had a bad code on it and was not "new" Luckily the ebay seller returned it without any issue. Anyway maybe run it by the dealer and see if they can marry it. But yes the fob will definitely need to me programmed by dealer
Old Aug 14, 2012 | 09:51 PM
jjnoble's Avatar
jjnoble
This is probably going to look like crap and hard to read, but here it is.
Table 3-2. TSSM Key Fob Assignment
1 Set
RUN/OFF
switch to
OFF
Verify that security lamp is
not blinking (vehicle is disarmed)
This assignment procedure
must
be completed with no
pauses between steps
greater than 10 seconds
2 Turn
IGN
key
ON
-OFFON
-OFFON
Press
left
turn switch
2 times
and
release
1-3 flashes turn signals & indicators
depending on vehicle configuration
(See section under 3.3 TSM/TSSM
VEHICLE DELIVERY regarding battery
disconnects.)
1 flash-Worldwide TSM, no
security
2 flashes-North American/
Domestic configuration
TSSM
3 flashes-European/HDI configuration
TSSM
Press
right
turn switch
1 time
and
release
1 flash turn signals & indicators
5 Press
left
turn switch
1 time
and release 2 flashes turn signals & indicators
Press and hold
key fob
button until
confirmation is received
2 flashes turn signals & indicators This may take 10-25 seconds
If you have two key fobs, press and hold
button on second
key fob
until
2 flashes turn signals & indicators optional step
8 Turn
IGN
key OFF
Old Aug 14, 2012 | 10:00 PM
PistonPuller
1 Set
RUN/OFF
switch to
OFF
must
2 Turn
IGN
key
ON
-OFFON
-OFFON
Press
left
turn switch
2 times
and
release
disconnects.)
security
TSSM
TSSM
Press
right
turn switch
1 time
and
release
5 Press
left
turn switch
1 time
Press and hold
key fob
button until
button on second
key fob
until
8 Turn
IGN
key OFF
That will not work on his bike. That procedure was for the older model security fobs. Pre 06? I believe maybe older. The ones that were not proximity fobs. For the OP it will have to be done at a dealer. No way around it
Pappy1
2014-2024 Touring Models
Oct 18, 2014 09:27 PM
MachU
Aug 24, 2014 09:11 PM
rdbeard
Jun 9, 2014 06:23 AM
Tri Glide
Nov 7, 2012 07:11 AM
dspencer
Oct 8, 2010 07:10 AM
