Top fork nut size ??
Old Aug 17, 2012 | 03:49 PM
smithbrl's Avatar
smithbrl
Originally Posted by iclick
I used the 36mm wrench in the tool kit the first time I changed the fork oil, but it is a bit too large for the fork caps, which are 1 3/8" (35mm). The second oil change I couldn't remove the caps with that wrench, as I had tightened them more than the factory did. I was concerned that I might damage either the wrench or cap if I forced it since the two weren't an exact size match, so I ordered the 1 3/8" wrench that I now use only for this task.
I'll probably have to get the 1 3/8 end wrench as well. The 36 mm has been working but it is a little aggravating because it's bigger and by the time the notches catch on the bolt I can only turn it a tiny bit, so it takes several attempts to get it loose enough to turn by hand.
Old Aug 17, 2012 | 04:12 PM
BlackPearl#1's Avatar
BlackPearl#1
Call me over prepared, heading for home now and should be good. Also not pictured is an impact driver for screws to drain old oil out.
Roadking04
Mar 22, 2010 06:30 PM
kylant
Jul 29, 2008 12:36 PM
harleykris
Feb 6, 2008 02:58 PM
harleykris
Feb 6, 2008 02:50 PM
neville
Jan 28, 2008 01:33 PM
