Anyone had this issue?
Old Aug 18, 2012 | 10:11 PM
CGreasamar's Avatar
CGreasamar
Default Anyone had this issue?
I noticed today that the gas tank on my 03 EGlide is crooked. I did the engine/drivetrain alignment a while back so I rechecked it again today and it was dead on. Measured a couple points and I am sure it the tank. When sitting on the bike the front of the tank is pointing to the left. I am assuming I can try to bend the front mounting tabs to get it straight. Anyone dealt with this. Thanks
Old Aug 19, 2012 | 12:32 AM
jjnoble's Avatar
jjnoble
I'm not crooked and I don't have issues. I had a great childhood.
Bending the tabs could cause the paint to crack and peel. If it does, it will rust. I suppose it could be the tank but it seems more likely to be the forks or the bars. Where are you measuring to and from?
Old Aug 19, 2012 | 08:03 AM
Uncle Larry's Avatar
Uncle Larry
I'm thinkin' that if it took you a long time to notice ... odds are no one else will.
Old Aug 19, 2012 | 08:11 AM
Weavr99FLHT's Avatar
Weavr99FLHT
I thought that too on my '99 but turned out that when the bike was pointing straight, the fairing was off a little bit giving the illusion that the tank was off. I had to replace the fairing mount brackets when they broke so took time to make sure everything aligned before I started tightening everything.
Old Aug 21, 2012 | 08:18 PM
CGreasamar's Avatar
CGreasamar
Well to took all of your advice and didn't mess with the tank before further investigation. I did a hillbilly fix on my left inner fairing bracket a while back cuz I noticed it was broken and I think that threw my fairing off. I went out for a ride and watched closely. I found that if I rode with only my right hand on the bars everything seemed good. I measured the bars to the passenger grab rail studs and they are the problem. Didn't think bars would cause that but obviously they can. Thanks for the help!
WoodButcher66
2014-2024 Touring Models
50
Mar 27, 2020 02:08 PM
phillyrube
Powdercoat & Paint
Sep 28, 2011 11:35 AM
srhen
Aug 5, 2010 10:50 AM
Rodman813
Mar 27, 2008 10:57 AM
harleydad
Sep 12, 2006 07:05 PM
