Perhaps not enough so that you feel it pulsing, but perhaps enough to push the pads and calipers further into the caliper housings than is normal. (Normally, the pads are all-but touching the surface of the rotors, and move very little when the brake is applied.)
What this means is that the "first push" of the pedal has to move the calipers and pads before building up the required pressure -against- the rotor to make the brake effective. Pumping the brake overcomes this, and then the brakes -seem- to work normally.
But -- release the brake, and the wavy rotor again pushes the pads/calipers further back into the housing, and the next time you go to apply the rear brake -- same thing all over again.
Is this what you're experiencing?
I had the same problem on my '00 Road Glide. Replacing the rear rotor solved the problem immediately.
YEP, I have a warped rotor ... I jacked up the bike and I hit press on the pedal and all is good and then I rotate the wheel and as I do I see a gap of 1/8"-3/16th" and then press the pedal and it goes to the end of it's travel (hitting floor board bracket ).. The warped rotor is pushing the brake pads outward and then when I want to use the brakes I have to pump the brakes.... Thanks for the help !!!!!!!
One more thing what should I get for new rotors floating, aftermarket, etc.
That is what is happening , will take a look at rotor , BUT it would have to be very warped as I can push the pedal all the way to the floorboard bracket. Thanks for the reply ,I'll take a look ..
so i got this same thing, in the middle of a ride my rear brake went all the way to the floor. my buddy who is a HD mechanic looked it over and after throwing on new pads (because mine were done) says its the rear master, i looked online for a rebuild kit and there are two sizes 3/4 and 5/8in bore
