2007 ultra classic will not start.
Old Aug 20, 2012 | 07:07 PM
gunsmith02's Avatar
gunsmith02
Stage II
Default 2007 ultra classic will not start.
I just bought a 2007 ultra classic. I got bike home with all accessories like tour pak etc. Everything is portable. I wanted to see of tour pak would light up with wires under seat and it did. I went to start bike and there is nothing. Security key light goes out but I have nothing when start button pressed.
Old Aug 20, 2012 | 07:12 PM
Nute's Avatar
Nute
Not trying to be smart here but are you 1 in neutral and is the kill switch on the right hand side in the "on""run" position.
Old Aug 20, 2012 | 07:16 PM
Dionicio's Avatar
Dionicio
Got Her in neutral, have the engine switch in the run position. Not trying to be a smart a$$, I been there and done that. Welcome to the forums. DAMN HE BEAT ME TO IT!
Old Aug 20, 2012 | 07:18 PM
eagle bud's Avatar
eagle bud
also if you have a security system from harley change the batterys in the fobs that happend to me called local hd shop thet said to try it and it worked for me good luck
Old Aug 20, 2012 | 07:56 PM
sargek's Avatar
sargek
Yep, the key fob is a proximity device and needs to be in your pocket when starting, or close. Did the turn signals flash alternating back and forth when you tried to start? If so, the "alarm" is going off. If they did not, you may have another issue.
FYI: the key fob takes a flat 'CR 232" battery about the size of a penny.
Old Aug 20, 2012 | 08:05 PM
gmc's Avatar
gmc
Check your ignition fuse under the left side cover. Does your fuel pump work, should be able to hear it when you turn switch on.
TooSlow
Jul 13, 2015 12:01 PM
scionracer
Sep 25, 2014 10:27 PM
Cooter383
Jul 31, 2014 08:32 PM
OLD 96
Jan 20, 2009 10:24 AM
gandy dancer
Motorcycles For Sale
Jun 25, 2008 04:53 PM
