tirer preasures
Old Aug 20, 2012 | 06:45 PM
rufasim's Avatar
rufasim
Default tirer preasures
I know the answers that I am going to get. Look at the side wall. It is dark out and I can't see. I believe the side wall read that 40 psi for stock tires on a 2012 sg. I just got a tpms and took a ride to test it out. It reads that I have 44 psi when the tires are hot. My question is this. How much preasure should there be when the tires are hot and cold.
I looked in the manual but I could not find it in there either. Thanks for any help tht you might be ab le to give.
Jim
Old Aug 20, 2012 | 06:49 PM
DannyZ71's Avatar
DannyZ71
Always check pressures when the tires are cold. Don't worry about hot temps, all that is figured in the making of them. And don't use the pressures listed on the sidewall. Check your owners manual. The same tire can fit many different bikes. Each one may have a different pressure recommendation for safety. Just because one bike can safely handle the tire with 50 psi in it, it doesn't mean any other bikes will.
Old Aug 20, 2012 | 06:51 PM
Dionicio's Avatar
Dionicio
Going by the pressure on the tire sidewall is only good for bicycles. I have a 08UC, and tire pressure is front 36psi, rear is 40psi. It should be in Your owners manual.
Old Aug 20, 2012 | 06:54 PM
keiththor's Avatar
keiththor
Agreed - it's in the owners manual in the area that has the capacity tables.
2010 Road King - 36 front, 40 back.
Old Aug 20, 2012 | 06:56 PM
103 sedona orange's Avatar
103 sedona orange
I run 40psi front/rear per HD. I use nitrogen. 2011 FLTRX
Old Aug 20, 2012 | 06:57 PM
rufasim's Avatar
rufasim
Thank you all. I am an idiot. I found it in the owners manual. For those that are interested, 36F, 40 R. Thanks again all!
Jim
Old Aug 20, 2012 | 07:14 PM
checkers's Avatar
checkers
"Zackley" what he said.
Old Aug 20, 2012 | 08:27 PM
TUCCI's Avatar
TUCCI
pretty much the same with mine.....36 front 41 rear.
Old Aug 20, 2012 | 08:33 PM
FDHOG's Avatar
FDHOG
It's also on the frame sticker on the left down tube.
SoftailBrian
Aug 15, 2017 10:05 PM
Knights2TheEnd
Jun 20, 2012 09:38 AM
FenderGuy53
Aug 1, 2011 01:30 PM
Geoff
Oct 22, 2009 07:00 PM
Manish_Hawg
May 23, 2006 07:22 PM
