ABS operation?
Old Aug 25, 2012 | 08:51 PM
P51Driver's Avatar
P51Driver
Default ABS operation?
Today was the first time I had the ABS on my bike kick in.
I was making a quick stop when a old guy pulled out in front of me.
Not a panic skidding type of stop but a quick stop.
I applied the front then the rear brake almost at the same time.
The interesting thing is the rear brake ABS kicked in but the front brake ABS didn't kick in. The front wheel didn't skid.
So my question is does it take more for the front ABS to kick in as the weight transfer to the front wheel causes the rear wheel to be light hence starting to skid first?
Old Aug 25, 2012 | 09:10 PM
mkguitar's Avatar
mkguitar
ok,
this is basic motorcycle 101- and you should know this...
when the bike slows the weight shifts forward, OFF of the rear wheel so that it can lock or skid easily--- this weight transfer allows MORE stopping force from the front tire
the brake and abs systems are independent front/rear
mike
Old Aug 25, 2012 | 10:03 PM
RollaMo's Avatar
RollaMo
ABS only activates when it senses one of the wheels locking up.
As you noticed, since your front wheel didn't lock up ABS didn't activate on that wheel.
What you describe is perfectly normal, and what you would expect.
Originally Posted by mkguitar
ok,
mike
Old Aug 25, 2012 | 10:11 PM
Mark_H's Avatar
Mark_H
Not only is it basic motorcycling 101...if your back tire skidded your ABS malfunctioned. The whole point of ABS is it never lets you skid.
Old Aug 25, 2012 | 11:19 PM
motorlessons's Avatar
motorlessons
All of the above answers are correct, and there's another factor:
Most motorcyclists don't practice braking. That giant HD Touring brake pedal just invites a person to think of a 1955 Buick, and stomp down on the brake. Getting guys to use the correct amount of rear brake is a challenge.
Since you have ABS, you can practice braking very safely. You should go to a good spot, and see what you can do with the front brake, and then practice adding in the rear to get the hang of it.
Harris
Denver, CO
www.youtube.com/conedown
Old Aug 25, 2012 | 11:27 PM
motorlessons
This video shows braking without using the ABS, but you get a good idea of how much weight transfer gives power to the front brake. Watch the forks compress during the braking portion (see how the lights come down toward the fender).
It's easiest to see in the first part of the video, when the forks rebound as I come off the front brake; and easier still if you watch it in full screen.
Harris
Denver, CO
Old Aug 26, 2012 | 01:12 AM
mkguitar's Avatar
mkguitar
you can ignore anything I wrote- pay careful atention to Harris.
and send away for his Lessons.
he is smarter than the average...Bear.
Mike
Labrador
Feb 19, 2018 11:25 AM
Ikickem
Jun 24, 2012 03:04 PM
dfndr
Apr 12, 2012 09:21 AM
JR-Boston
Wheels/Tires
May 10, 2010 01:51 PM
cfoster80
Feb 9, 2009 11:01 PM
