New Tires 10+ Touring
Old Aug 26, 2012 | 09:24 PM
Stew Pidaso's Avatar
Stew Pidaso
The 63Hother and 65H refers to how many belts if its bias or radial and its speed rating. Look up on a reference on tire codes to find exactly what the code you are considering to compare apples to apples. Do your homework for the best decision for YOU.
Old Aug 27, 2012 | 12:09 AM
jjnoble's Avatar
jjnoble
buy the tires on line and take your bike to an indie, stay away from the dealer. You should be able to save over $200.
A little of $300 for both tires
$75 for R&R on rear
$40 for R&R on front
approx $450 for both out the door and you don't do anything but bring them the tires and the bike. You can remove the wheels yourself and save a little more, but for me it is not worth it.
Old Aug 27, 2012 | 04:51 AM
WildBill2566's Avatar
WildBill2566
Originally Posted by Stew Pidaso
A bit on tire sizes. 130/70B-17 means your tire is 130mm wide/ 70% of width=sidewall height-17" wheel. The other numbers and letters refer to how it is constructed. B=black side wall W=white stripe WWW=Wide white wall
The B refers to tyre construction and means bias belted, if it was an R it would be a radial
Old Aug 27, 2012 | 04:53 AM
WildBill2566
The 65 is the load index for the tyre and you are correct that the H is the speed rating for that tyre.
65 equates to a load rating of 290 Kg
H equates to 130 mph
Old Aug 27, 2012 | 07:05 AM
SmittyFXDL's Avatar
SmittyFXDL
Lots of good info here. Thanks for all the help.
Im still uncertain if I can use an AE on front tire as the AE is 80B and my stock tire is a 70B.
My front tire is a Dunlop 408 130/70B-17 and the American Elite I found on sale is a 130/80B-17
Old Aug 27, 2012 | 07:49 AM
skratch's Avatar
skratch
anthony, are you sure your front tire is a 130/70-17? the reason i ask is i have a 2010 fltrx (roadglide custom) which should be the same specs as your streetglide with the exception of the fairing and i have a 18'' tire on the front. unless you switched wheels, you should be running 18''.
there is no american elite available in 18''. in speaking with the dunlop rep, you have 2 options. one, go with the stock front tire and the ae in the rear. or 2nd, go with the e3 in the front, and the ae in the rear. the tread is compatible and the load rating is equivalent.
Old Aug 27, 2012 | 07:58 AM
luc.who's Avatar
luc.who
Originally Posted by scotracy
17k on tires? why would you want to replace a tire that has done so well? My Indy says stay with Stock Dunlops, best tire for the weight of a touring. And he only charges 30 bucks labor to change out rear.
+1 if you got 17K out of the stock tires, stay with them. You could be replacing the tires with something that gives you 8K per tire.
Old Aug 27, 2012 | 08:13 AM
SmittyFXDL's Avatar
SmittyFXDL
Man, I was pretty darn certain when I looked at tire yesterday, but now Im at work and in looking up specs online it shows 18. Ill double check this evening and post back.
I am also in dire need of bi focals but have been putting that off for some time.
Old Aug 27, 2012 | 12:02 PM
Stew Pidaso
Wildbill....you are correct. I was wrong about the specs. Looks like I too have some homework to do!
Old Aug 27, 2012 | 03:18 PM
SmittyFXDL's Avatar
SmittyFXDL
I stand corrected. Have an 18 in front and AE comes only in 17 for front, as does the Michillin Commander II's. What a freakin gimmick. So only same tire configuration is to go with the stealerships overpriced 407's and 408's at around 500 bucks just for the treads not including installation. Man that sucks.
