View Poll Results: What is your Oil Preference?
Same Oil in all three holes
16.36%
Different oil in each
83.64%
Voters: 165. You may not vote on this poll
Yet another fluids thread....
Old Aug 31, 2012 | 07:43 AM
  #31
sergel's Avatar
sergel
All this debate about oil is a little ridiculous in my mind... Good oil is good oil...
I go for the simple oil change, best bang for the buck in my book...
Mobil 1 20W50 Vtwin for engine and primary
Mobil 1 75w90 for tranny...
At $10 a quart, can't find a better value. And the gear oil really quiets down the 5th gear whine...
What I am saying is just don't loose sleep over it...
Old Aug 31, 2012 | 08:01 PM
  #32
Lifeofchaos13's Avatar
Lifeofchaos13
Thanks to everyone that voted, results are interesting. Only 12% use the same in all 3 holes. Considering that Syn3 which Harley suggests for running in all 3 cost almost $20 per quart and you need 6 quarts per oil change no wonder.
Old Aug 31, 2012 | 11:07 PM
  #33
vickers1's Avatar
vickers1
I run HD primary oil and Amsoil in the engine. I run Amsoil gear oil in the transmission.
When I had my cams installed on my 2012, I changed over to my usual combo above. When I picked up the bike, all the usual ticking is completely gone. I think it is due to a combination of the Amsoil and the tighter tolerances on the rockers.
Old Aug 31, 2012 | 11:14 PM
  #34
wlibert's Avatar
wlibert
I run 4qts. of Amsoil 20w-50 in the engine
1qt. of Bel-Ray V-Twin trans fluid which is 85w-140 I believe in the trans, and I run 45 oz. of HD Formula+ in the primary.
Every thing works great.
Old Sep 1, 2012 | 12:17 AM
  #35
scotracy's Avatar
scotracy
Syn 3 all 3 holes... best the bike has run!
Old Sep 1, 2012 | 12:37 AM
  #36
Pioneer74's Avatar
Pioneer74
Don't know where you're shopping, but it's $12 at my dealer, and about $10 from lshd1.
Old Sep 1, 2012 | 01:22 AM
  #37
smithbrl's Avatar
smithbrl
I run motor oil in the engine because it's an engine.
I run gear oil in the transmission because I've always run gear oil in manual transmissions.
I run Formula+ in the primary because HD recommends it and I've never dealt with this chain/clutch business before.
I don't think one oil is the best for all 3 holes. I think the different oils were engineered and manufactured for different applications.
One oil in all 3 holes may work fine. We read about it a lot here.
Old Sep 3, 2012 | 11:40 AM
  #38
Lifeofchaos13
Thanks for the link for lshd1 I will be ordering from them for sure. Local HD dealer here sells syn3 for 15+ a quart.
Old Sep 3, 2012 | 12:32 PM
  #39
scrawfordFLSTC's Avatar
scrawfordFLSTC
Mobil 1 20w50 in the motor, HD 20w50 in the primary, Mobil 1 75w90 in the trans
Old Sep 11, 2012 | 08:36 PM
  #40
FLHTPI0550's Avatar
FLHTPI0550
6th Gear
Motor: Amsoil 20w50 synthetic
Tranny: Amsoil Severe Gear
Primary: Type "F" auto transmission fluid
Best combination I've found yet, and buying amsoil as a perferred customers saves a few bucks, http://www.amsoil.com/storefront/def...i=1&zo=1791369
