I have a 2000 FLHR i have Vance and Hines turn down mufflers on it on both sides but it isnt true duals the from cylender runs out the right side the rear cylinder has a Y and runs in with the right side and left side mufflers id like to go to true duals my questin can i buy just the true dual head pipes and keep the rest of my setup? or do I need something else? or an entirely different setup? any info would be greatly appreciated
You have a couple options, and yes you can keep your mufflers.
1 - Buy a set of true dual pipes, install your existing mufflers. You have many choices here, but it is the most expensive, but best looking option.
2 - Buy a true dual conversion kit from fullsac.com (there may be others) and just convert what you have for less costs. Install your existing mufflers.
There you go.
Just wondering why you want to make the switch. My bike runs great on the stock head pipe. Sound? Heat? Performance?
Hoping for a better sound i just seems it could a little louder/deeper and it does get pretty warm. I know the big vance and hines have baffels but i worried cutting them down or removing all togather will do more harm than good. Ive found $275 for tru dual head pipes but wasnt sure if i can run with my current setup? I type in all caps at work sorry for them lol
