Newbies headlight works on high only.
Old Aug 29, 2012 | 07:16 PM
Timekeeper10's Avatar
Timekeeper10
Default Newbies headlight works on high only.
What? I discovered that my regular beam headlight does not work. The high beam and the spot do. Anything to check beside the plug or just go buy anoher headlight?
Old Aug 29, 2012 | 07:19 PM
soos's Avatar
soos
Buy another bulb.
Old Aug 29, 2012 | 07:20 PM
bigheadted's Avatar
bigheadted
You could make sure that you have power at the plug on low beam before you go get a new bulb though I usually carry a spare on longer rides just in case.
Old Aug 29, 2012 | 07:21 PM
Timekeeper10
Originally Posted by soos
Buy another bulb.
thanks, I have not had it off, I htought it was sealed.
Old Aug 29, 2012 | 07:22 PM
Iceman24's Avatar
Iceman24
Ditto...bulb's probably got a bad filament. Is it stock? If so...time for a upgrade>
http://www.discountfleetsupply.com/tlc27270c.html
Timekeeper10
But I do think that puts me in the running for the dumbest question of the night.
Old Aug 29, 2012 | 07:24 PM
soos's Avatar
soos
I have an '06 and I am on my 3rd lamp. I run on low beam 99% of the time. They just wear out. I also find it easier to change it out by removing the fairing.
Old Aug 29, 2012 | 07:26 PM
Timekeeper10
Its stock, I guess I will have to start researching upgrades.
Old Aug 29, 2012 | 07:29 PM
Timekeeper10
thanks, I have to replace the main support bracket end anyway.
Old Aug 29, 2012 | 07:33 PM
Iceman24's Avatar
Iceman24
Installed mine this past weekend...took all of 10-minutes. Just recommend the added HD light trim ring b/c the TruckLite protrudes out from stock ring ~1/2". The "French" (PN 69627-99) or "Visor" (PN 69733-05) will work...I did the Visor on my FLHX.
