Easy pull clutch?
Old Aug 30, 2012 | 10:24 AM
racedvl's Avatar
racedvl
Default Easy pull clutch?
I have a 2001 rk and right now I'm using a friends 2006 flhx. Wow, when did Harley go to this easier to pull clutch, and what can I do to make mine like that?
Old Aug 30, 2012 | 10:40 AM
Bill03E's Avatar
Bill03E
I think 06 is when they went to the easy clutch, with the improved ramp, you can buy a clutch ramp kit for your bike , I am sure someone will chime in with a part #
Old Aug 30, 2012 | 10:44 AM
Redbeard719's Avatar
Redbeard719
Look in the parts catalog for the reduced effort clutch kit. It became stock in 2006.
Need to pull the primary cover and right side transmission cover to install. Best to get new gaskets for each while you pick up the kit.
And of course transmission and primary oils will be required too.
Energy-Dude's Avatar
Energy-Dude
Not sure on the year perhaps 06??? Harley makes a kit and so do a few others. Its a different ramp device where the clutch cable ties in under the cover on the side of the transmission. Do a search here or on google "Harley EZ Pull Clutch".
Old Aug 30, 2012 | 10:48 AM
TUCCI's Avatar
TUCCI
Sven as far back as 98 I dont recall the clutch being all that hard to pull?
Old Aug 30, 2012 | 10:52 AM
Pumba11's Avatar
Pumba11
I agree, my friends 07 is so much easier then my 99 RK. Plus mine has the single cylider caliper brakes.
However, I figure I can use some "Popeye arms" to impress the little lady so I'm leaving them as is.
Old Aug 30, 2012 | 11:07 AM
mkguitar's Avatar
mkguitar
the white brothers easy boy lite clutch used to cost $26 and takes 20 minutes to install --- more if the header has to come off.
now sold under the burly brand- ( who took over some of the white brothers stuff when they went under)
here is my tip:
ONCE the trap door bolts are loosened slightly,
roll your tires up on a 2 x 4, and put the bike on the jiffy stand-- ensure that it is stable- get a Pal to balance for you if needed...
you can then pull the trap door without dumping fluid all over the floor, about a tablespoon will leak out.
when putting the trap door back on, the new torque spec for the bolts is 25 ft lbs
this kit was a common mod back to late 80's.
mike
Old Aug 30, 2012 | 01:11 PM
racedvl's Avatar
racedvl
I have LARGE hands. The clutch is really not a problem. But that clutch is nice on that 2006. I could see where if I was stuck in traffic (happens a fair amount riding to work) the easy pull would be nice.
That being said. I did a little looking around and the kits are cheap. Might be a good winter project. Or the next time I change fluids.
Old Aug 30, 2012 | 02:00 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
I don't think it was standard equipment on 06 bikes, my 06 was pretty stiff, put the hydraulic clutch on mine, my friends 07 is still easier to pull than my hydraulic. If I had to do it again I would look at the Magura hdyra unit, it works in conjunction with the OEM manual throw out, maybe that and the ez pull together.
Old Aug 30, 2012 | 02:10 PM
tincup64's Avatar
tincup64
i have an hd easy clutch kit here i can sell you if you want it. shoot me a pm if interested.
tin
