06 RK front header pipe ?
Old Sep 1, 2012 | 06:28 PM
Roadie 49's Avatar
Roadie 49
Default 06 RK front header pipe ?
Dealer did a cam,cam chain adjuster,and oil pump upgrade on my
06 RK and four K miles later the cam chest cover is leaking badly.
Front header pipe makes it difficult to get to a couple of the lower
cover bolts, so question is will I have to remove the entire right side
exhaust system, so as to be able to install a new gasket.
Old Sep 1, 2012 | 07:10 PM
HammerheadC4's Avatar
HammerheadC4
I have true duals, I always removed the front pipe when I took off the cam chest cover to check the tensioners.
I also ran a thread chaser in the bolt holes and used a pipe cleaner or Q-tip to make sure there was no oil in the bolt holes before replacing the cam chest cover. I sprayed some parts cleaner on the Q-tips, then used some dry ones. Blue loc-tite on the cam cover bolts....Inspect the mating surfaces, cam chest and cam cover.
I used the service manual for tightening sequence and torque values.
I did this with the bike on the kickstand, you will lose some oil, not too much. I put some plastic under the cam chest/over the frame.
I did this job several times (checking the tensioners) I think I used a new gasket every other time.
I always used a new exhaust gasket.
Old Sep 2, 2012 | 06:39 AM
grbrown's Avatar
grbrown
You've answered your own question! If you can't get to the screws.....
Old Sep 2, 2012 | 10:36 AM
Roadie 49's Avatar
Roadie 49
Thanks for the reply, appreciate the input from someone that knows what ther're doing.
Old Sep 2, 2012 | 10:48 AM
Roadie 49's Avatar
Roadie 49
Thanks for the thoughtless,useless reply.
Explains why you have over 11K post.
JayStronghawk
Jul 30, 2019 01:44 AM
HDmikie
Engine Mechanical Topics
Mar 16, 2012 08:18 AM
bigsofty
May 14, 2010 10:11 AM
YellowHawk
Jun 7, 2009 01:11 PM
snotrocket18
Exhaust System Topics
Jan 10, 2007 10:59 AM
