06 Street Glide tail lamp assembly question
Old Jan 22, 2007 | 06:58 PM
tgaetto's Avatar
tgaetto
Default 06 Street Glide tail lamp assembly question
I want to put the pictured light/plate mount on ditch the stock set up and install the bag spoilers for use as turn and brake has anyone done this and is the tail light mounted with the 3 hole or is the fender punched out like the lowerider? I have been out a million times but never look at the mount on the fender seems I always foreget????
Thanks!
[IMG]local://upfiles/15114/06FFCA7543FE47A9B522C11E57051E51.jpg[/IMG]
Old Jan 22, 2007 | 07:07 PM
bountyhunter's Avatar
bountyhunter
Default RE: 06 Street Glide tail lamp assembly question
Would be difficult to adapt the piece that you show. SG assembly is mounted with 2 bolts, take a look and you'll see how the fender is stamped. Better off with a Kuryakyn curved SG plate frame, perfect fit!
Old Jan 22, 2007 | 07:10 PM
Bryan TTM's Avatar
Bryan TTM
make some rubber spacers to contour to the fender curve on one end, strait on the other for the back of the plate
Old Jan 22, 2007 | 07:17 PM
tgaetto's Avatar
tgaetto
Anybody know if they make one with the halph moon to fit the SG????
ORIGINAL: bountyhunter
Old Jan 22, 2007 | 07:29 PM
iclick's Avatar
iclick
ORIGINAL: tgaetto
I don't know what you mean by "half moon," but I agree with Bountyhunter than the Kuryakyn curved cover is the way to go for SG's, and that the one you pictured probably would not work well. I just installed my Kury cover today and it looks great.
Old Jan 22, 2007 | 10:47 PM
hartick's Avatar
hartick
that kury frame looks pretty good on their website. does it leave the stock blinkers? or is that all one piece? i plan on switching all the lights to leds, turn and brake and that would be a start.
Old Jan 22, 2007 | 11:41 PM
iclick's Avatar
iclick
ORIGINAL: hartick
Follow this thread for more photos of the Kury frame: https://www.hdforums.com/m_1084971/tm.htm
The frame uses the stock light housing and only replaces the black stock license support. You must remove the light housing to bolt on the Kury frame.
venom4949
May 12, 2016 08:18 PM
Vancebagger
Sep 25, 2014 11:15 AM
tinker1
Sep 5, 2011 07:57 PM
miketedesco
Mar 26, 2010 09:25 PM
2short2ride
Dec 9, 2007 06:14 PM
