clutch issue?
Old Sep 2, 2012 | 10:30 PM
cjbmustang's Avatar
cjbmustang
Default clutch issue?
Hey everyone, I'm posting this for my father.
He owns a 2000 FLHRI (road king, fuel inj). I always thought the clutch on his bike was a little off compared to other bikes...when letting out the clutch lever it grabs at the top instead of when you start to release the lever. He went for a ride yesterday and was telling me that his bike would not let him downshift from 5th or maybe it was 4th; it was blocking him out. He eventually got it to downshift.
I messed with the cable adjustment to see if the cable had stretched, but it did not seem to make a huge difference. Next step will be removing the derby cover and adjusting it there.
He did have his 10,000 mile done at a dealership about 2 years ago (less than 5k on the bike since then).
Am I headed in the right direction?
Thanks,
Chris
Old Sep 2, 2012 | 10:36 PM
pdzani's Avatar
pdzani
Yes you are going in the right direction, you will need to check the adjustment at the clutch itself behind the derby cover. When the clutch plates start to wear this adjustment is critical, many times adjusting the cable itself will not fix it. Good luck.
Old Sep 2, 2012 | 10:56 PM
cjbmustang's Avatar
cjbmustang
sounds good.
i'd assume the dealer would've done this during his 10k. maybe they did it warm or something else. i'll post back when I adjust it tomorrow. thanks
Old Sep 2, 2012 | 11:04 PM
Stiggy's Avatar
Stiggy
You can not adjust the clutch in any way, shape or form from the cable adjuster on the clurch cable, in spite of what you may read here sometimes.
Loosen the cable adjuster, adjust the screw behind the derby cover, and adjust the cable back out to your preference.
(And never pull the clutch lever in while in the middle of doing the clutch adjustment. Bad things can happen)
Old Sep 3, 2012 | 12:32 AM
mkguitar's Avatar
mkguitar
a manual would be a good idea...it'll pay for itself with this job.
it seems that the clutch may need adjustment
it is almost certain that the cable needs adjustment
- as above these are 2 different things--- and they BOTH have to be right.
it is quite possible that the shifting problem is elsewhere:
check fluid levels
check primary chain adjustment ( if the mechanism is worn, replace with Hayden M6)
check that the shifter is not bottoming on the floor board, and that the entire linkage is secure tight and not binding...
and that the splined attachment to the tranny is tight
mike
Old Sep 3, 2012 | 04:14 AM
shovel52's Avatar
shovel52
Remember to check everything a dealer may have touched. It seems like dealers never tighten the nut on the clutch hub and the screw gradually backs out and changes the clutch contact point continually until it is readjusted and finally tightened properly. I am getting so I hate to have anyone touch my machine. When I have warranty work or recall work done, I always ask what they did exactly and take it straight home and open it up and check every nut and bolt. Especially critical adjustments and life altering stuff. Maybe, somewhere there are good dealerships and competent mechanics. Did I wake up cynical?? Ken
Old Sep 3, 2012 | 09:22 AM
1flhtk4me's Avatar
1flhtk4me
I would first lube/inspect the clutch cable then follow the adjustment procedure.
Old Sep 3, 2012 | 12:06 PM
cjbmustang's Avatar
cjbmustang
He has the service manual. I was more or less looking for where to start. I will check the clutch when i get home.
As for the cable having nothing to do with the clutch adjustment itself...? If the cable was too tight wouldn't it preload the clutch causing premature wear?
Old Sep 3, 2012 | 06:26 PM
cjbmustang's Avatar
cjbmustang
adjusted the clutch, a lot better now. thanks fellas, he's happy
Old Sep 3, 2012 | 06:57 PM
gump305's Avatar
gump305
Glad you got this fixed, and thank you for helping out your dad.
