Use the front brake to stop as well. It is important to have both feet available for two-up stopping. Also ensure your passenger is not moving around at stops until you get used to the bike. Not always about weight.
Tend to agree on this one. If your right foot is tied up applying the only braking you're using then it's not as immediately available should the bike tip to the right. Stop with the bike going dead straight. Use the front and rear brakes but be ready to have both feet available to hold the bike up when it comes to a complete stop (you really shouldn't have your feet down until the bike is fully stopped - it's dangerous). Use of both feet, as necessary, when riding 2 up is one of the only two disagreements I have with Harris Neil's Motor Lessons, an otherwise excellent read (https://www.hdforums.com/forum/touri...s-booklet.html).
I found do not look to the sides when stopping. Focus only on stopping and looking forward so you can see the angle of the bike and adjust. After a complete stop then look for traffic.
It may be beneficial to have the bike lowered (front & rear), which also lowers the the center of gravity of the bike, and it's passengers.
I can imagine how much more difficult for me it would be if my bike was 2" higher than it is currently.
FWIW, one or both of my feet are touching the ground as my bike comes to a complete stop.
If you keep both feet on the floorboards until the bike stops and it is slightly tilted, there's a much higher risk of you being unable to keep the bike from tipping over.
Never use the front brake to stop. Only to slow you down. Use the rear brake to make that last little move to stop. Make sure your passenger sits perfectly still. If they have to shift weight, shift to the left as that will be where your left foot will be down. If you start to go to the right, you will take your foot off the rear brake, and use the front brake to actually stop. That is bad.
After being off a bike for 30 years, I had lots of trouble with my heavy *** Road King when a passenger was on. They'd see an "almost stopped" situation as an opportunity to move around.
I haven't had that problem, even with a passenger, but when I come close to stopping I only use my index finger to break, gently, don't crank down on that sucker
first thing, can you reach the ground rite. you don't have to be flat footed, but you need good enough footing to control the weight of the bike. second is, it is a heavy bike. you need the strength to wrestle it around.
a lowering kit makes a world of difference. im 5'8", i was about to sell my bike after it almost fell over on me a few times. all it took was an inch drop in the rear so i could reach the ground rite.
keep the bike uprite and strait when coming to a stop. i use both brakes to slow down, then only the front for the last foot or so.. if you try to come to a complete stop with the rear brake, by the time you put your feet down, you could already be leaning, to the side
Eyes on the horizon makes a very big difference in smoothness and stability when coming to a stop. It's very counter-intuitive, at least to me, but makes a big difference when I make myself do it.
