Silverish slime in chaincase
Old Sep 4, 2012 | 06:52 PM
Keys's Avatar
Keys
Default Silverish slime in chaincase
I have this thick gray/silver looking grime on the walls of the inside of my chaincase. My clutch seems to be slipping badly when i'm riding (that's what the symptoms suggest). I have only small doubt, that this thick greasy slime is what is causing it somehow. Bike has only ~15,000 miles on it.
Has anyone else had this problem before?
Does anyone know what it is?
Does anyone know what caused it? (mixing oils?) ??
Help please.
Thanks!
08 FLHRCI
Old Sep 4, 2012 | 07:05 PM
Dallas 13's Avatar
Dallas 13
Just had my primary apart, the gray coating is normal. I think it is a byproduct of the chain aerating and flinging oil.
Old Sep 4, 2012 | 07:10 PM
RANGER73's Avatar
RANGER73
It's fine metal shavings. Flush and refill.
Old Sep 4, 2012 | 07:12 PM
Mike T's Avatar
Mike T
It's condensation mixing with the primary oil.
Old Sep 4, 2012 | 07:27 PM
hoofnhog's Avatar
hoofnhog
Mikey got it........ water and oil make gray sludge...........
Old Sep 4, 2012 | 07:54 PM
timbo141's Avatar
timbo141
If you go on shorter rides it will be worse, long rides burns off the condensation
Old Sep 4, 2012 | 07:58 PM
soft 02's Avatar
soft 02
And do a complete clutch adjustment.
Old Sep 4, 2012 | 08:16 PM
springer 03's Avatar
springer 03
normal, drain and change.
Old Sep 4, 2012 | 08:57 PM
Keys's Avatar
Keys
From the looks of it I will have to scrape it off of everything. If the clutch plates are off, will using a degreaser inside the chaincase cause harm to anything?
Old Sep 4, 2012 | 09:30 PM
soft 02's Avatar
soft 02
Depends on the degreaser. I use starting fluid to clean the inside of my primary. If I were you put in some new oil and change it in a week or two and keep doing this till the fluid is clean.
