Brake pad glue
Old Sep 5, 2012 | 02:14 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Default Brake pad glue
Hey just wondering... When I did my rear brakes the pads came with a tube of glue or goo or whatever it's called to apply to the back of the pad so it would adhear to the piston. The fronts didn't come with that stuff. So I put them together without. I assume it's to keep the pads from touching the disc when they are in the running mode.
What do others do? Do I need that stuff or no?
Old Sep 5, 2012 | 02:21 PM
rochkes's Avatar
rochkes
Are you sure it is not lube for the caliper piston?
Dennis
Old Sep 5, 2012 | 02:46 PM
SIDECAR BOB's Avatar
SIDECAR BOB
Agreed either piston lube or anti squeak to kep metal to metal noise down where pad sits on caliper piston , or could be antisieze for the sliding pins. pads touch the rotors at all times on disc brakes
Old Sep 5, 2012 | 02:50 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It was for putting on the back side were the piston rubs the steel backing to keep it from chattering. (at least long enough to everthing seats in) least you bring them back. They must be the harder no dust pads. Nothing goes on pad side. In fact you need to be careful not to get it on that side. I would have thrown it away.
Old Sep 5, 2012 | 02:52 PM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
Silicone looking stuff?? Likely anti-squeel..rears are notoriuos for squeeling
Old Sep 5, 2012 | 02:56 PM
zeus33's Avatar
zeus33
yeah thats the stuff I guess. It comes with a template that you stick to the back of the steel pad so you only put the goo where the piston would sit against the back of the pad.
So... not necessary on the front then?
Old Sep 5, 2012 | 02:59 PM
fathertime's Avatar
fathertime
not necessary unless they start sqeeling..frt arn't usually as bad for it as rear
Old Sep 5, 2012 | 03:17 PM
zeus33's Avatar
zeus33
ok thanks guys. Come to think about it my rears squealed like a pig before I changed them out. Now, not a peep. So mystery solved. It's anti squeak.
Old Sep 5, 2012 | 03:26 PM
Jackie Paper
Do you have the 4 piston rear caliper?
Old Sep 5, 2012 | 03:48 PM
zeus33's Avatar
zeus33
Yes I do. Why?
Twospot
Jun 2, 2016 04:32 PM
grumpy56
Oct 22, 2010 07:17 PM
Uncle Scrooge
Wheels/Tires
Aug 29, 2009 04:33 PM
marshrat
Jun 10, 2009 01:01 PM
The Jimmy
Jun 23, 2006 01:55 PM
