Hola,
Bienvenido al foro. Supongo que el Inglés no es su lengua materna, así que estamos teniendo problemas para entender tu pregunta, espero que puedan entender mi español. Lo que algunos de nosotros estamos asumiendo es que se han despojado perno de la cubierta derby. ¿Es esto correcto?
Take a small center punch and make a punch on the bolt head at about 10:00.
Then angle the punch about 45 degrees down and keep tapping it counter clockwise until it breaks free.
If you stripped a T-27 ( yea, nobody here has done that ... like when I tried reading my inch-pound torque wrench without my glasses and only saw newton scale ) ...
Hola,
Your spanish is not bad!! lol yeah I stripped a T-27 on the derby cover I will try to post pics, thanks!!
If you stripped a t-27 ( yea, nobody here has done that ... Like when i tried reading my inch-pound torque wrench without my glasses and only saw newton scale ) ...
I rounded out not one but two of the screws. Drilled off the head and the cover came right off, then I was able to grab what was left of the screws with needle nose and back them out.
