Whats up with the lights??
Old Sep 8, 2012 | 10:31 AM
kfstreetglide's Avatar
kfstreetglide
Originally Posted by dansflhti
It is strange that your lo beam is out,but your spots work.They are tied together.I had a similar situation on my 06 Standard(except for the lo beam thing),it was the lighting relay.
where is your lighting relay located? i have a similiar thing happening on my 07 (except for the lo beam thing).
Old Sep 8, 2012 | 07:38 PM
dansflhti's Avatar
dansflhti
I'm remembering now that it is my 09 that the lighting relay went.IIRC it was under the left side cover.A toasted battery caused the relay to fail in my opinion.The battery died in traffic and while trying to restart her,the dials were swinging like crazy,the alarm was going off,and that relay was buzzing like a bee.
Old Sep 10, 2012 | 12:20 AM
Timekeeper10's Avatar
Timekeeper10
Default Figured some of it out.
Ok, So I replaced the fuse using info from forum members. Te fulse box comes out like a chinese puzzle. Turned the switch on and the running lights came on, not the headlight. So I went to O'Reillys and got a new 9003 bulb, installed it OK (not sure that damn chrome headlight rings fits right) So it works now!. Went out last night to see the balloon launch at the lake and guess what...no running lights. So its off to Big Bore Cycles to have them trouble shoot a short that is blowing the fuse. The only other thing I have done to the bike is pull the outer fairing to check out the broken fairing bracket and then put it back on. Guess the headlight was just a coincidence. thanks forum
Old Sep 10, 2012 | 10:41 AM
kfstreetglide
Keep us posted on what you find out, I have the same problem on mine, checked all the wires going from the fuse to the taillights and all were good. So i removed the outer fairing to look for bare wires and could not find any, while i was looking for bare wires i noticed all my fairing support brackets were broke so i replaced all of them and put back together and went for a ride and now the tailight fuse will not blow. Just curious on what they find out on yours.
Old Sep 10, 2012 | 10:53 AM
yesitsdon's Avatar
yesitsdon
I have a 93 FLHS with no running lights and no tail-lights but my turn signals and brake-light still work. Would the accessory fues be located in the same place for my model? I don't think a lighting relay was used for my year, correct?
City Worker
Mar 20, 2018 05:32 AM
Lowboy2200
Jan 26, 2012 01:43 PM
sdlimey
Electrical/Lighting/Alarm
Oct 26, 2011 10:51 PM
bear68
Apr 3, 2010 06:17 PM
dclapp
Jun 11, 2006 07:26 PM
