Caliber true duals?????
Old Jan 23, 2007 | 06:12 PM
BIGSKY_FLHXI's Avatar
BIGSKY_FLHXI
Default Caliber true duals?????
I found me some used true duals at a junk yard that seem to be in good shape. The guy doesn't know what brand they are but the removable end caps have Caliber imprinted on them. Does anyone know what brand they might be and if they are good pipes? the are the head pipes and slipon mufflers.
Thanks for you help,
Mike
Old Jan 23, 2007 | 06:16 PM
v2in's Avatar
v2in
Default RE: Caliber true duals?????
Those are Samsons high line exhaust system. They are a 4 step system and sound very good. I think you'll like them. check out www.samsonusa.com
Old Jan 23, 2007 | 06:21 PM
BIGSKY_FLHXI
what do you mean a 4 step system?
Old Jan 23, 2007 | 06:23 PM
tgaetto's Avatar
tgaetto
https://www.hdforums.com/fb.asp?m=1071986Samson I think
ORIGINAL: BIGSKY_FLHXI
Mike
Old Jan 23, 2007 | 06:27 PM
v2in's Avatar
v2in
4 step system is a system that gets bigger diameter at each curve in the pipe. It comes out of the head at an inch and 7/8 and gets bigger. I think it's 2" going into the muffler, so no other muffler would work with that header pipe. You put those pipes an air box and a PC 3 that bike will run.
Old Jan 23, 2007 | 06:31 PM
bountyhunter's Avatar
bountyhunter
Too much gap between the saddlebag[:'(]!
Old Jan 23, 2007 | 06:44 PM
BladeMan's Avatar
BladeMan
I've got em. They sound good but the heat shields aren't the greatest.
Old Jan 23, 2007 | 07:04 PM
BIGSKY_FLHXI
what do you mean the heat shields aren't the greatest? what is wrong with them. also, how much louder are they then the SE slipons with the stock head pipes?
if you don't mind....what did you pay for them?
Old Jan 23, 2007 | 07:24 PM
BladeMan's Avatar
BladeMan
The heat shield coming around the curve at the back pipe doesn't fit real good. I had SE slipons on my last bike and I think the Calibers sound better. They might be alittle quieter at cruising but when you get on it the Calibers are louder. They are a lot quieter than the samson rolled thunders.
Old Aug 8, 2007 | 06:04 PM
euskalharley's Avatar
euskalharley
What about performance????
aaronmcb80
Exhaust System Topics
Dec 23, 2016 07:28 AM
BJFLHT
Jul 6, 2011 12:34 PM
JayDee5150
May 16, 2008 12:34 AM
omega5m14
Apr 26, 2008 08:32 AM
LTDDD
Nov 2, 2007 07:36 AM
