Still using the 'Kill Switch'?
Old Sep 14, 2012 | 01:43 PM
  #161
frog13's Avatar
frog13
Originally Posted by BigGdawg
I typically use Shell oil.
I used to, but now I run WD-40 in my engine. It does take a lot of time to spray all those cans in there but it's worth it, I have no problems with moisture in my oil ever again and the engine runs ohhhhhhh so quiet. I also use it to lubricate my kill switch, even though I rarely use it.
Old Sep 14, 2012 | 02:05 PM
  #162
mike5511's Avatar
mike5511
I'm really surprised you didn't know about WD in the gallon cans!
Old Sep 14, 2012 | 03:36 PM
  #163
simpkinst's Avatar
simpkinst
Originally Posted by ddm502001
As we rode our new ride thru CO last month I stopped my ride at a Indy shop where I used the thumb switch to shut the engine off as I had done for the majority of the last rides I have owned; a tech close to me saw me do that and stepped over to offer some advice, DON"T use the kill switch as a routine shut off.
His reasoning for the info was at MoCo school he was informed this has a potential to damage the ECM if done as a routine, it has to do with power flows into and out of the module and can not only be damaging to the module it can during regular use reset the logic to base parameters leaving the engine in a poor run mode until it can re-learn the parameters for clean operation.
I have stopped the use of the switch, fuel mileage is up, engine is more responsive and as to date seems to be quite correct in the advice. Anyone else hear this??
I would find a new Indy shop.
This is the dumbest thing I have heard in awhile. Its in the manual for a reason, and its not to break **** to get more business.
Sounds to me like these 2 morons are trying to impress you with all their deep. secret knowledge that no one else has.
I bet next they will tell you your gigahurtz generator needs calibrated becase the factory does'nt know how to do it right.
Old Sep 14, 2012 | 04:14 PM
  #164
Terrabella's Avatar
Terrabella
Sometimes I wonder about people. The kill switch isn't going to do a dam thing that would harm the ECM. I mean, commonsense has to prevail at some point.
Old Sep 14, 2012 | 04:16 PM
  #165
mulestang 09's Avatar
mulestang 09
1st Gear
my owners manual says to use the kill switch to shut the engine off, so I started using it.
Old Sep 14, 2012 | 04:22 PM
  #166
Big Trev's Avatar
Big Trev
I got a pound(sorry Dollar) says it ain't
Old Sep 15, 2012 | 02:30 AM
  #167
rasa777's Avatar
rasa777
I'm thinking of not using it cause I'm afraid the extra second it takes to turn the other switch off might drain the battery a bit with my running lights on, my headlight on brights, and a pair of fog lights on all the time.....same with starting the bike....heard that on cold starts it's more of a drain on the battery having all the lights on while starting the bike.
Also I was told not to start the bike until after the orange engine light turns off on the speedo...
any thoughts?
Old Sep 15, 2012 | 03:10 AM
  #168
OLD 96's Avatar
OLD 96
Never have and never will use the kill switch. Just like any other kill switch on any other piece of machinery it is there in case of an emergency. Thanks to God I have not had that much of a case of emergency. I turn off the ignition switch. Just like I did before there was a "kill switch".
Old Sep 15, 2012 | 03:39 AM
  #169
Scaredofrain's Avatar
Scaredofrain
Originally Posted by T_Dogg80
I'm I the only one with a manual that says to always shut off the engine with the kill switch?
No but, you are the only one that reads the manual before things go wrong and not after.
Old Sep 15, 2012 | 03:48 AM
  #170
Scaredofrain
It don't matter one way or the other. But to avoid future problems I will, from now on, not switch off the bike at all. I will ride it all the time!
