Still using the 'Kill Switch'?
Old Sep 15, 2012 | 01:29 PM
  #181
Jinks's Avatar
Jinks
Originally Posted by ddm502001
So I get redirected by a tech at the local stealer to this page, from 2010:
https://www.hdforums.com/forum/touri...on-switch.html
Seems the same issue pops up every few months and yes, there is something to it, the tech at the dealer went thru a current MoCo electronics class last month and they no longer recommend the use of the kill switch save for emergencies. There is a "potential" for the operator to roll in or out of the throttle during the use of the handlebar kill switch, doing so can cause a reprogram to the ECU idle control logic and if performed 'wrong' often enough can damage the ECU. He had written notes from his class supporting the claim.
Just sittin' here reading some of these justifications I have to ask, What prevents the throttle from being "off idle" no matter which switch is used? Not using the kill switch doesn't guarantee a perfect idle. Neither does using the kill switch. Both the ignition & kill switches interrupt the same circuit, & the distance between them is insignificant in terms of time when related to electron flow.
If the ECU needed some sort of "soft shutdown" like your computer I'm reasonably sure there would be a separate power circuit & a built-in program for that purpose. Relying on getting a consumer to follow some mythical sequence is too dumb for even the MoCo.
Old Sep 15, 2012 | 03:34 PM
  #182
ddm502001's Avatar
ddm502001
Now I am sorry I even asked if anyone else had heard this as to a OP, a few had seen/heard this same topic, seems three shops I have spoken with, two indy, one stealer and all MoCO authorized don't know squat. You use your kill switch with no issues then you are not seeing a problem yay for you, I had not either but the possibility to cause some problem evidently has existed for a few years for posts to show since 2010. Kill the messenger and you get little input later.
Old Sep 15, 2012 | 03:39 PM
  #183
blarg's Avatar
blarg
I heard running the motor will eventually wear it out. According to the dealer and every indy I've asked the only way to prevent this is to park the bike in a temperature and humidity controlled environment and never run the motor.
Old Sep 15, 2012 | 03:46 PM
  #184
lumper's Avatar
lumper
So.... what is the kill switch for then?
Whats its purpose and why is it on the bike?
Lump
Old Sep 15, 2012 | 04:08 PM
  #185
patriot2500's Avatar
patriot2500
I was taught to shut the bike off via the kill switch. I'll have to look into this further.
Old Sep 15, 2012 | 05:35 PM
  #186
Jinks's Avatar
Jinks
Lump
If memory serves (& that is questionable) the first ones for street use were introduced on early Honda 750's. The reason was that the motor would overpower the brakes if the throttle locked wide open. (that part is fact, I've seen a first year Honda 750 power down the highway with the front wheel locked) You could thumb a "kill switch" without removing your hands from the handlebars. A commercial version of the wrist strap kill switch on lots of high performance vehicles at the time. It quickly became an industry standard on any motorcycle that wanted to claim any power/speed. In reality it's use is extremely limited. Modern motorcycles have "tilt switches" that kill the motor if the machine exceeds a certain tilt angle, & most have either push/pull throttle cables or fly-by-wire throttles that are more likely to restrict your throttle than to cause wide open acceleration.
Old Sep 15, 2012 | 07:40 PM
  #187
1st 96 ultra's Avatar
1st 96 ultra
well asked one of the local dealers about this today and the service rep told me they are told to use the kill switch on the newer bikes , something about the crank sensor learning , so one more answer
Old Sep 15, 2012 | 10:56 PM
  #188
vzts4q's Avatar
vzts4q
Well I use mine because of the 750 Kawasaki H2 I had in 72. For the youngsters here it was the fastest and one of the worst handling bikes of the time.
(http://en.wikipedia.org/wiki/Kawasaki_triple)
Once a carburetor slide stuck open and there was no kill switch. Getting it stopped without killing myself was interesting. So since then I am VERY comfortable using the kill switches provided every time I shut down a bike.
to say the least
Old Sep 16, 2012 | 03:52 AM
  #189
sycle1's Avatar
sycle1
My 2012 FLHX owners manual says use Kill switch, my 2008 FXDB owners manual said to use Kill switch, my 2007 sporty says in owners manual use kill switch, my old 2001 Sporty owners manual and workshop manual say use the kill switch.
Anyone seeing a trend here?
Old Sep 16, 2012 | 07:04 AM
  #190
kredin's Avatar
kredin
The trend: HD may be using previously published information in current HD manuals.
You guys keep researching this topic... I'm going for a ride... and then using my kill switch when I'm done.
