Still using the 'Kill Switch'?
Old Sep 15, 2012 | 05:10 AM
  #171
Timmy B's Avatar
Timmy B
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
ok. just read the OP. Kill switch shuts the bike off. And if you forget you pu the kill switch on when you shut it off, well, stop drinking. Just having a laugh, but really. Pre-ride inspection????
Old Sep 15, 2012 | 05:13 AM
  #172
cdemarse's Avatar
cdemarse
Its true. I used the kill switch all the time and I've had to replace the oil pan filter plug THREE times already!!
Old Sep 15, 2012 | 06:31 AM
  #173
VTL nut's Avatar
VTL nut
Originally Posted by blarg
If you use the ign switch to kill the motor you get better gas mileage...but if you do "run, stop, run, stop, ign, off, ign, off, acc, ign, acc, off, left rurn signal, right turn signal, left+right turn signals together, then put the bike in second gear, and honk the horn twice" it unlocks the "unlimited gas" cheat code.
Now thats funny and made this read worth while, Thanks blarg................
Old Sep 15, 2012 | 07:51 AM
  #174
lionsm13's Avatar
lionsm13
Never have used the kill switch and probably never will.
Why would you want to use 2 switches to turn off your bike when 1 will do?
Does Not make sence to me.....
Just silly...
Old Sep 15, 2012 | 07:57 AM
  #175
skeeter 250's Avatar
skeeter 250
Don't need any switch. Every time I fall over, my bike turns off.
Old Sep 15, 2012 | 08:21 AM
  #176
ddm502001's Avatar
ddm502001
So I get redirected by a tech at the local stealer to this page, from 2010:
https://www.hdforums.com/forum/touri...on-switch.html
Seems the same issue pops up every few months and yes, there is something to it, the tech at the dealer went thru a current MoCo electronics class last month and they no longer recommend the use of the kill switch save for emergencies. There is a "potential" for the operator to roll in or out of the throttle during the use of the handlebar kill switch, doing so can cause a reprogram to the ECU idle control logic and if performed 'wrong' often enough can damage the ECU. He had written notes from his class supporting the claim.
Old Sep 15, 2012 | 09:24 AM
  #177
mgmmgm's Avatar
mgmmgm
I used to enjoy a good cigar once in a while with some whiskey.......
This thread my take a spliff too get through though.
Wear some gloves, full stop, hit N, and reach down and pull the spark plug wires off the plugs
Old Sep 15, 2012 | 09:38 AM
  #178
mgmmgm's Avatar
mgmmgm
Default No sh....ith?
That was great even without the spliff
Old Sep 15, 2012 | 11:19 AM
  #179
dablues61's Avatar
dablues61
This realy works, havnt been to a gas station for almost 4000 miles!
Old Sep 15, 2012 | 12:03 PM
  #180
fabrik8r's Avatar
fabrik8r
Alright then, if we can accidentally reprogram the ECU idle logic, then it would seem reasonable enough that there must be a correct procedure to intentionally reprogram the ECU idle logic. What is the potentially damaging result of this "reprogramming" either accidental or intentional, can we raise or lower our idle RPMs? This sounds a lot like one of those fantastic explanations when there really isn't an explanation. It must be an extreemely rare occurance or there would be a bulletin about it.
