Still using the 'Kill Switch'?
Old Sep 11, 2012 | 08:59 PM
  #61
oneballz's Avatar
oneballz
Originally Posted by Pumba11
But the primary reason is so you don't look like a fool trying to start your bike and it doesn't, because you forget to turn the kill switch back on.
Originally Posted by stro1965
This is the ONLY reason I'd ever be reluctant to use it, bit me in the *** one time.
Really?
I dont want you to ever look bad, so next time try using your thumb and hitting both buttons at the same time in the same direction. As you'll notice the start and run buttons both go in the same direction. Unless you start your engine with your index finger. Its a habit thats easy to learn.
Old Sep 11, 2012 | 09:01 PM
  #62
FDHOG's Avatar
FDHOG
6 pages on how to turn off your bike!
Old Sep 11, 2012 | 09:14 PM
  #63
booch's Avatar
booch
If you use the kill switch instead of the ignition shut off with synthetic oil in your bike, it will void your warranty.
If you have decatted your pipe, and don't use the kill switch you will get a 25% increase in torque, except if you are running a Phase 7 light instead of the HD Led, then again, your warranty is voided.
Even worse, if you are going to use the kill switch, don't fill your oil more than 3.65 qts or it will come out your air filter onto your pants, again, voiding your warranty.
I could go on and on.
Old Sep 11, 2012 | 09:17 PM
  #64
tccraiger's Avatar
tccraiger
good one!
Old Sep 11, 2012 | 09:21 PM
  #65
drukanfu's Avatar
drukanfu
Whats a Kill Switch ?
Old Sep 11, 2012 | 09:30 PM
  #66
Yellotang's Avatar
Yellotang
I don't think I am drunk enough for this thread........
Old Sep 11, 2012 | 09:31 PM
  #67
layne's Avatar
layne
I use the "kill" switch to turn off the engine and the ignition switch to turn off the stereo.
Old Sep 11, 2012 | 09:33 PM
  #68
T_Dogg80's Avatar
T_Dogg80
I'm I the only one with a manual that says to always shut off the engine with the kill switch?
Old Sep 11, 2012 | 09:36 PM
  #69
lh4x4's Avatar
lh4x4
Until recently the kill switch was the proper way. The previous key switch had the entire electrical load going through them and the kill switch was a way to make the ignition switch last longer.
Now the ignition key switch only activates a relay that provides full power to the starter.
So ether way is okay. The info about any magical improvements in performance is beyond bogus.
Old Sep 11, 2012 | 09:41 PM
  #70
T_Dogg80's Avatar
T_Dogg80
I agree. Performance improvements from not using the kill switch seems counter-intuitive to my common sense.
