Still using the 'Kill Switch'?
Old Sep 11, 2012 | 05:44 PM
  #51
r.i. streetglide's Avatar
r.i. streetglide
wheres the poll, hehe hehe
Old Sep 11, 2012 | 05:49 PM
  #52
Gliden's Avatar
Gliden
Bs. I use it every single time on every single bike I ever owned. Kill switch then key off.
Maybe Dawg will jump in.
Old Sep 11, 2012 | 05:58 PM
  #53
mmcbeat's Avatar
mmcbeat
I never use the kill switch.
sidebar: about a month ago, I bought a new scooter. The service guy pulled it around to the front of the dealership where the sales guy & I were waiting. Sales guy went over a few things on the bike and asked if I had any question, I said "no, I'm good to go". I got on the bike and I couldn't start it - took me a little while to remember to check the kill switch.
  #54
Jim Dawson's Avatar
Jim Dawson
Originally Posted by blarg
The radio has an internal battery that keeps your settings for a few minutes but if you disconnect the battery for about an hour your radio will lose it's settings. Also the standard ecu reset procedure is to disconnect the battery for a while.
My radio seems to only lose the clock settings but retains the memories. My ECM certainly doesn't lose the map I loaded months ago.
Old Sep 11, 2012 | 06:16 PM
  #55
blarg's Avatar
blarg
Not the map... That's in nvram, but the ecm's adjustments to the map and "history" are wiped if you disconnect the battery.
  #56
okcjetmech's Avatar
okcjetmech
Sounds like we need to dig into the wiring diagram..........
Old Sep 11, 2012 | 06:59 PM
  #57
Punjabi Rider's Avatar
Punjabi Rider
I only use the kill switch if I'm parking on up hill or down where I have to hold the front brake while bike is running in gear but then turning off the ignition I turn it back on to make it easy to start, but my wife always use the kill switch and every time I've to move it I say some bad words before I start it. On normal surface I always put in neutral turn off the ignition but wife again is opposite .
Old Sep 11, 2012 | 07:51 PM
  #58
geezer glide 56's Avatar
geezer glide 56
I always use the key switch...Motorcycles did not have a handlebar run/off switch when I started riding.
Old Sep 11, 2012 | 08:42 PM
  #59
Ghosttrain1's Avatar
Ghosttrain1
From: Austin, San Antonio, Canyon Lake, Houston, Palestine, Texas
Wow. This is a buzzard thread. I always use kill switch, then turn off on/off switch. Gonna have to try just leaving kill switch on. We shall see
Old Sep 11, 2012 | 08:44 PM
  #60
Ghosttrain1
Originally Posted by Ghosttrain1
Wow. This is a bizzare thread. I always use kill switch, then turn off on/off switch. Gonna have to try just leaving kill switch on. We shall see
Stranger things have happened.
