Need advice. Flywheels damaged.
Old Sep 12, 2012 | 08:22 PM
texasridr's Avatar
texasridr
Default Need advice. Flywheels damaged.
2003 Road Glide, 80KMI: **disclaimer** I don't pretend to be a mechanic, so something I say might sound wrong.
I was hearing a knock in the front cylinder. Took it to my Indy. He says the flywheels are out balance causing the run-out to be .015. I could see the wobble in the flywheel shaft while he rotated the engine. He said it also damaged the cams when the chain got excessively tight and loose. I think the knock I heard was the chain hitting something?? The tensioners were fine though.
His estimate to fix was $4,000. There was a $1200 crank set (which could be a couple hundred less if going back to stock), about 1200 in labor, cams for 300 or so... then quite a few "incidentals" like bearings, synthetic oil, and some "other stuff". I really couldn't focus on what some of the small items were.
I told him this just would not work at all, that a Re-manufactured Harley engine shouldn't cost me much more than that so why wouldn't I choose that route instead?
I told him we'd talk again tomorrow, and for him to check into having the flywheel repaired/rebalanced at a machine shop? Can they straighten a warped flywheel shaft?
Shouldn't I be able to get a rebuilt bottom end for much less than what he's originally quoting me? I really don't plan on doing an engine build; it was not on my agenda. A stage 2 would be enough improvement for the type of riding I do. What's a practical solution here?
Thank you!
Old Sep 12, 2012 | 09:07 PM
Bill03E's Avatar
Bill03E
A reman motor is about $3500.00 and then you will probably spend about $800.00 to install it.
Old Sep 12, 2012 | 09:56 PM
slickrick_58's Avatar
slickrick_58
This was my solution:
http://www.revperf.com/TwinCam/twinCamCrank.html
Old Sep 13, 2012 | 04:05 AM
grbrown's Avatar
grbrown
I suspect what he said (I can understand some of it going in one ear and out the other!) is that your crankshaft has gone out of alignment, which has caused it to also go out of balance. That shift to .015 runout is not healthy. Slickrick's suggestion is well worth looking into, although it sounds as if your man is talking of a new or rebuilt crankshaft for that money he quoted you.
Hopefully after a night's sleep and a deep breath you can talk things through with him once more and take more of it in this time! The trouble with problems like this is that the price never comes down, in my modest experience, but if the crank can be recovered Slickrick's way, that should help.
Old Sep 13, 2012 | 05:59 AM
cochon's Avatar
cochon
A remanufactured motor also comes with a 1year unlimited mileage warranty. If you have .015 runout, your crankshaft is bent.
Old Sep 13, 2012 | 06:20 AM
imrotton2's Avatar
imrotton2
[quote=cochon;If you have .015 runout, your crankshaft is bent.[/quote]
is it really bent or scirrored
Old Sep 13, 2012 | 06:26 AM
grbrown's Avatar
grbrown
Wink
Most likely scissored! In other words one flywheel has moved relative to the other one. I can't imagine a circumstance in which one would actually bend.
Old Sep 13, 2012 | 06:29 AM
texasridr's Avatar
texasridr
Originally Posted by slickrick_58
What would be a reasonable labor cost to pull and reinstall a crank, cams, and necessary bearings and such?
I already have 80K on it (previous owner actually, but always Dealer maintained for EVERYTHING). I thought the top end might need refreshing before too long. Maybe I SHOULD consider just doing a Re-Man job??
Old Sep 13, 2012 | 07:09 AM
1flhtk4me's Avatar
1flhtk4me
I would call and ask the crank guys about pricing.If parts of the crank have to be replaced,this will sure add to the cost.
With the indy doing the work,now is the time for up grades.
Old Sep 13, 2012 | 08:03 AM
0ldhippie's Avatar
0ldhippie
I guess it would depend on how much ya love this bike and how long ya plan on keeping it. There are used motors out there ya could put in it. The Harley crate motor isn't a bad deal but it is just a stock motor for not alot less than a good rebuild. If ya plan on keeping the bike rebuilding/upgrading your motor is the way I'd go. Since it will be all apart there are many performance/reliability options that won't increase the labor or even parts costs too much and you can end up with whatever performance/reliability you want. Might as well make a 103+ as long as it's apart.
