2005 FLHRCI Engine Build-FINALLY! Good Quote?
Old Sep 13, 2012 | 11:26 AM
Hawgzilla's Avatar
Hawgzilla
Lightbulb 2005 FLHRCI Engine Build-FINALLY! Good Quote?
Good Morning,
After 7 years of saving up H-D Visa Chrome Bucks, I finally have enough to pull the trigger on pepping up the TC88 on my RoadKing Classic! The Harley tech and Harley service writer sat down and generated the attached quote.
Disclaimer: After many years on car and motorcycle forums I KNOW there will be replies like "You can get 10x the whp at 1/10th of the cost in the aftermarket! Are they including KY Jelly?!?" I am requesting reviews and guidance here, but keep in mind that I need to do this through my dealership so I can use the roughly $3300 Chrome Bucks to defray as much out-of-pocket expense as possible.
I'm not looking for Honda VTEC-engine-like high revs with this V-Twin, but I do seek to get as much asphalt-ripping-spinning-the-earth-with-my-rear-tire torque as I can get outta this TC88. I have riding buddies who START with the 96 engine and go up from there. I like keeping up. I'm also looking to keep as much of the RKC "classic" look where possible without adding performance bits that are incongruous with the look.
Does there appear to be anything wildly amiss from this quote? Is there anything additional you would recommend? I'm just looking for some technical/performance advice from my Harley bros.
Thanks in advance!
Attached Thumbnails 2005 FLHRCI Engine Build-FINALLY! Good Quote?-hdntx-engine-build-quote-crop.jpg
Old Sep 13, 2012 | 03:27 PM
pit1600's Avatar
pit1600
Just thinking like you to upgrade my old '04 Ultra. I asked for a quote to cyclerama after seeing their dyno result :
Perfect Street 95" Kit Strong Bottom End/Mid Range Motor. 9.5:1 Compression Ratio
Port and polish heads to Perfect Street 95" specifications. Install bronze alloy valve guides and hone to size. Performance valve job, multi angle valve job on the intakes, radius on the exhaust. Set valve to valve and seal to retainer clearance. Set installed valve spring height. Install larger valves, heavy duty valve springs, CC Chambers, mill heads, flow test and velocity probe ports.
Torque plate bore, hone cylinders, and set ring end gap.
Bore throttle body and port intakes.
PARTS:
(1) CR-95 Custom Forged Piston Set
(1) Set of CR-575 Gear Drive Cams w/New Bearings, < Gears
(4) Performance Lifters
(1) Adjustable Push Rods w/Tubes
(1) Performance Gasket Kit
(1) Heavy Duty Valve Spring Kit
(2) 1.90 Intake Valves, Ni Coated SS
(2) 1.63 Exhaust Valves, Ni Coated SS
(4) Viton Valve Seals
(4) Bronze Alloy Valve Guides
(1) Heavy Duty Cylinder Head Studs
Shop Supplies
Total $3002.00 Via Paypal + Shipping & Handling
Other performance options to consider:
_ Core Heads, Cylinders, and Throttle Body $550.00
_ Oil Cooler w/Adapter and Anti-rotation Device $342.00
_ SE Heavy Duty Clutch Spring $29.95
_ Rinehart True Dual Exhaust System. List $1025. Our Price $899.00 *
just to share, i'm not a vendor. Here is the dyno sheet :
http://www.nightrider.com/biketech/street_tc_engine.htm
Old Sep 13, 2012 | 05:59 PM
Bigdad68's Avatar
Bigdad68
I just paid $4800 out the door at an Indy for the 95 kit Andrews cams, upgraded cam tensioner and oil pump, I dumped my screaming eagle tuner and put in the Zippers auto tune no more Dyno costs in my future. I love it it is like a different world!
Make sure they are upgrading the cam plate and pump.
TO34
Dec 26, 2011 05:19 PM
davidslay
Exhaust System Topics
Dec 23, 2011 11:19 AM
SURFOR Chop
Jun 3, 2009 01:54 PM
cnnesseth
Oct 5, 2007 02:48 PM
zoomie67
Dec 11, 2006 03:47 PM
