ANOTHER DO NOT DO THIS
Old Jan 24, 2007 | 09:20 PM
oley55's Avatar
oley55
Default RE: ANOTHER DO NOT DO THIS
if they are actually made of Lexan, I amazed it could break. Acrylite, Plexiglas, and others yes, but not Lexan. that stuff is almost impossible to crack or break. I've played with Lexan before(not a cycle shield) and found it to be malleable like steel. folded it back and forth many times before it would actually crack and break (just like steel). then took apiece over to the anvil and hammered on it and it flattened out just like you would a piece of metal. yes the surface scratch factor was low, but the resistance to fatigueseemed very high.however, all this was done when I was still down in the Miami area and the outside temp was probably in theoh so sticky high 96's.
and yea, I'm still inclined to go with the Clearview.It'snot like they cost a fortune. I just like the whole recurve design to push the air a little higher than a non-recurve.
ORIGINAL: Bryan TTM
i've cut & drilled lexan windows on my outlaw car, never a prob....it was in the 40's ...no pilot hole...slow speed...impatient the last few turns and pushed abit too hard i guess...i just ordered a new one in the height i wanted...i broke it, they didnt so i will not ask for help...i did ask him to expedite one for me tho....didnt want to cut the top cause i'da lost the cool recurve....i've had a few shields and i liked the clearview the best, so yall dont not buy one cause i screwed up....just dont do what i did []
Old Jan 24, 2007 | 09:24 PM
Bryan TTM's Avatar
Bryan TTM
had to have been the cold....it just split in an instant....costs bout 100 bucks shipped
Old Jan 24, 2007 | 09:25 PM
Primo's Avatar
Primo
WTF Bryan, Couldn't you find your sawzall?
My dad used to modify plastic windows with the old hot nail method. Heat one up under a torch or even the stove, lineup and press down.
Have no idea if it works on lexan but heck you got a coupla' broken pieces. Might wanna try it to see if it works. If nothing else you can let the rest of know if that old method works on modern plastics or not.
Primo
P.S. The true sign of a man is one who is willing to admit his failures to others so that they may learn from his mistakes. Thanks Bryan.
Old Jan 24, 2007 | 09:30 PM
Bryan TTM's Avatar
Bryan TTM
i'll do some experiments on the broke stuff tomorrow...and fill yall in
Old Jan 24, 2007 | 09:38 PM
TexasBowhunter's Avatar
TexasBowhunter
BONEHEAD...
save a piece for me as well I might of had a complete set of reamers to get you up to the size of hole you were looking for
We all learn from out mistakes...
Live and Learn...
Old Jan 24, 2007 | 09:58 PM
EasternSP's Avatar
EasternSP
Hey Bryan, I'm inclined to think that maybe the Lexan was flawed to begin with. Unless you where using a center punch to mark the spot you wanted to drill, I really don't think it should have cracked like that either.
Was it a straight crack or jagged?
I'll bet you can drill in other parts of it and it won't crack.
Old Jan 24, 2007 | 09:59 PM
High Gear's Avatar
High Gear
Like Oly55 sais , It probably isn't Lexan .
I've worked with Lexan ( A General Electric polycarbonate )material many times over the years at work .
Very easily machined and very strong material ( expensive also) .
Any other acrylic doesn't even come close , you have to treat it with kid gloves and it still can crack .
Makes me leary of a windshield made of anything other than Lexan
Old Jan 24, 2007 | 10:12 PM
Manish_Hawg's Avatar
Manish_Hawg
[sm=ttiwwp.gif]
Old Jan 24, 2007 | 10:16 PM
Bryan TTM's Avatar
Bryan TTM
tomorrow...figured all yall would just geta good laugh...didnt dawn on me to take pics and do some exploratory probin
Old Jan 24, 2007 | 10:54 PM
Basz's Avatar
Basz
Man you crack me up
