I have been using clay bars for my cars and trucks for awhile and can really see a difference. I clayed my 2012 truck which was only 6 months old and I could feel the clay cleaning the surface. Especially on the hood. I was surprised at how much contaminates were on a new truck. Anyway, I decided to clay my 2009 bike for the first time and have to say, I could not feel the same cleaning as I do with the trucks. I thought that at least the fairing would need a good claying? However it was pretty smooth to begin with. Is it because it plastic versus metal? I didn't notice it on my tank either.
Does anyone else notice this?
Plastic versus metal won't matter since you're cleaning paint either way. You probably clean your bike more often, ride it less than your car and don't park it outside as much.
I also use clay bars on my vehicles, it is amazing what that stuff pulls out of the paint. My guess would be the bikes tend to get cleaned and waxed a bit more. I know in my case the bike has a much easier life than my cars weather wise.
True. I never clean my truck like I do my bike. I am the once a while clay and full detail on my truck. I hate to say it but the rest of the time I am a drive through car wash guy. Man those thing really arent good for your car. Once a year usually right before the winter, I will do a full detail and good wax on my cars and truck. I do wipe the bike down and will use a detailer on it lot more than the truck. Maybe thats why I havent been detailing it as much
How does one use clay bar and is it easy to F up the surface if not done right?
you need to keep the surface the clay is sliding over lubricated. some use a simple soap and water solution, i prefer a quick detailer.
tear off a small chunk of clay (1/2 the size of your palm) and slide it along the paint. keep folding it over to expose clean areas of clay as you go. wipe up behind you with a clean microfiber towel as you go.
First time you use a clay bar you will say "F that I am not rubbing that on my paint" You are actually taking a piece of clay and rubbing it on the paint to remove contaminates. Three things that I can suggest would be
1 Make sure the surface is good and wet. Dont rub on a dry spots. I use the detailers but some use just water
2. If you drop the clay bar, dont reuse it. Get a new piece.
3. Knead the clay a little before you start.
