I got a little shimmy??
Old Sep 19, 2012 | 08:26 AM
shagnasty's Avatar
shagnasty
Default I got a little shimmy??
I went to Deals Gap this past weekend on my street glide to ride the dragon. Ive riden it several times before so I knew what to expect and most importantly I know my limitations! I have riden this bike on it once before without any issues. This time however i found that when I was deep into a tight turn the handlebars shook about 1/2 to 3/4 inches back and fourth until I got out of the turn. Very odd feeling. Any ideas what caused this? The bike is a 2011 and it has 9,000 miles.
Old Sep 19, 2012 | 10:24 AM
BigGelvis's Avatar
BigGelvis
It wasn't your handlebars turning, it was your rear swing arm flexing or moving.
I have had people ride behind me in hard turns and they say it looks like the rear wheel is loose and wobbling. When it does this, the rear of the bike is being steered by the wobble of the rear wheel.
Here is a video of what it looks like in an extreme example on a police bike........
Old Sep 19, 2012 | 10:37 AM
mongomark's Avatar
mongomark
I wouldn't be so quick to discount what could be happening in the front end. If the steering neck bearing are out of adjustment, some weird things can happen both with front end shimmy and instability in turns. I've got a bagger brace on my 07 to correct (minimize) the problems in the rear but I recently developed some issues up front that are beyond normal. The steering neck adjustment brought it back to normal. To tighten it up further would require the Tour Track triple tree which is on my Christmas list!!!
Old Sep 19, 2012 | 10:46 AM
JohnnyC's Avatar
JohnnyC
Start simple .... check / adjust tire pressure. And if you have an air ride adjust that.
Everyone will be ready to jump into stabilizers, and worn bearings but I've found even a pound or two change in my tires can give me a lot of cornering issues.
Old Sep 19, 2012 | 02:25 PM
shagnasty's Avatar
shagnasty
I dont think its in the rear end as Ive riden this bike on the same road without this happenig before and not that it couldnt be but I understood that the new frame design eliminated that issue for the most part. I tend to believe it may be steering neck adjustment. Is there a way to check this?
Old Sep 19, 2012 | 02:33 PM
BigGelvis's Avatar
BigGelvis
I don't claim to be a tech by any means. But I do know that any bike in a tight turn CAN NOT turn the bars as much as you say without running off the road or slamming you to the ground.
That tells me that the rear of the bike is "swaying" or wobbling. the front wheel stays on track and the rear is wobbling back and forth causing the appearance of the bars turning, because they are but it's the back of the bike moving, not the front wheel.
Think about it next time you are leaned over in a turn, try and turn the bars and see what happens.
Old Sep 19, 2012 | 02:35 PM
BigGelvis's Avatar
BigGelvis
Oh and I forgot, My bike is a 2012 FLHTK and it does this same thing sometimes. Not quite as extreme like in that video but it does it bad enough that my sister, who has never ridden a motorcycle, asked me why my rear wheel was wobbling after she was following me to dinner one day.
Old Sep 19, 2012 | 02:39 PM
shagnasty's Avatar
shagnasty
I wish I could describe it better but I feel solid in the seat of the pants so to speak. It just feels strange. never had it happen on this bike before or my 06 RKC.
Old Sep 19, 2012 | 02:42 PM
D1gger's Avatar
D1gger
perform a fall-away test. Lift the bike off the ground and disconnect the clutch cable from the lever. Turn the bars all the way to the left and let them go. Count how many swings before they stop moving. Any more than three and the head bearings are too loose and need adjusted tighter.
Old Sep 19, 2012 | 02:51 PM
BigGelvis's Avatar
BigGelvis
If it makes you feel any better, I didn't know mine did it untill my sister said what she said.
This was her exact words....
Sister: "Why does your wheel wobble like it was? Is is lose or something?"
Me: "WTF are you talking about?"
Sister: "When we were taking the off ramp from I-45 to beltway 8 @ 75mph, your rear wheel looked like is was lose and wobbling"
Me: "Hmmmmmmmmm I did feel that strange swaying feeling on that off ramp that I have felt a vew times?"
I have since then been alert and watched for it and now I can visualize what is happening when I feel it.
