Gear shift linkage
Old Sep 27, 2012 | 11:57 AM
Pondskipper's Avatar
Pondskipper
Default Gear shift linkage
I pulled the shift lever shaft and greased it up and refitted everything, replacing the stupid ball joints on the linkage with heim joints, shifts a lot smoother now with no more rattle from the shift set up.
Old Sep 27, 2012 | 12:17 PM
mikelikesbikes's Avatar
mikelikesbikes
Can you post pictures of this ? I have read about it before so curious.
Old Sep 27, 2012 | 12:22 PM
Pondskipper
Will have to take a couple of pictures.
Old Sep 27, 2012 | 12:24 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Originally Posted by Pondskipper
I pulled the shift lever shaft and greased it up and refitted everything, replacing the stupid ball joints on the linkage with helm joints, shifts a lot smoother now with no more rattle from the shift set up.
One of the best upgrades you can do is replace the ball joints to heim joints
Old Sep 27, 2012 | 12:29 PM
Scrmnvtwins's Avatar
Scrmnvtwins
I'm interested in the heim parts and where they came from. I had a ball fall out of the shift rod when it was worn out. Pulled into town and tried to downshift with nothing attached. Pulled into a station and found a wire tie from a bread wrapper to hold things together long enough to get home. Where can i get a Heim joint to replace ehte ball joints?
Old Sep 27, 2012 | 12:33 PM
Redbeard719's Avatar
Redbeard719
Ebay may not be a bad place to look.
http://motors.shop.ebay.com/i.html?_...ey+heim+joints
Old Sep 27, 2012 | 12:34 PM
Pondskipper
I got mine from True Value hardware.
Old Sep 27, 2012 | 12:36 PM
Gliden's Avatar
Gliden
Not a kuryakn fan but I bought the flame linkage. Very nice. It tightened things up and that linkage is a quality product.
Old Sep 27, 2012 | 12:51 PM
hillcountryflt's Avatar
hillcountryflt
Mine fell apart while my indy was working on it. I did away with the factory style and went with:
http://www.dragspecialties.com/produ...roduct%2F73826
It has a heim joint. Seems a lot better but perhaps another thing to rattle some.
Old Sep 27, 2012 | 01:02 PM
Sporty302's Avatar
Sporty302
Heim joints from H-D are part #33871-85B (sifter rod end) and were about $9.75 ea. a while ago. Cheaper can definitely be had elsewere!
